Replacing stock head lights with LED head lights
Discussion in 'Questions From New Drivers' started by GQ Trucker79, Nov 17, 2024.
  1. GQ Trucker79
    GQ Trucker79 Bobtail Member
    Nov 17, 2024
    I'm a company driver and I recently moved into a 23 peterbilt 579. The headlights are brand new but are not very bright. I suggested installing led lights but equipment manager claims they will burn up wiring harness. I can't see that and even talked with guy at pete store he agrees with me. Has anyone used LED lights and had them burn wiring harness? I need ideas for better light. Thanks
  3. blairandgretchen
    13,212
    70,208
    Dec 9, 2011
    South west Missouri
    Variations in amperage draw cause problems in much older units.
    Out of my league for newer trucks.
    The_vett, snowlauncher and D.Tibbitt Thank this.
  4. FLHT
    FLHT Road Train Member
    1,329
    2,261
    Aug 2, 2014
    Put them on my 06 and finally could see the road at night again.
    Did not burn up anything.
    Now if you buy some make sure it has the DOT approved in the glass.
    Dot will write you a ticket for unapproved lighting.
    The_vett and tscottme Thank this.
  5. tscottme
    tscottme Road Train Member
    If the wiring isn't made for the current of the LED lights, it will burn up the wiring. If you are lucky you just burn up the wiring and not set the plastic hood on fire. Check the aim of the headlights.
    Did you possibly get out of a car or truck that had the LED lights and these headlights are not as bright as those?
    The_vett Thanks this.
  6. RollinChaos
    RollinChaos Light Load Member
    123
    229
    Oct 6, 2024
    North Carolina
    LED bulbs are normally cool to the touch and minimal power draw.
    For those reasons I would think a 2023 truck would have LED already
    The_vett and lester Thank this.
  7. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    LEDs draw tiny tiny amounts of power compared to old incandescent bulbs, like fractions of power. what do new trucks have for headlights? projector? surely not incandescent.
    that said I've ran several different LEDs and not burned anything down. that's what fuses and relays are for
    The_vett and Goodysnap Thank this.
  8. Ridgeline
    22,101
    113,190
    OMG, the wire can handle the current draw but unless you have projection lights, don't bother. You will blind people and you don't want to do that.
    ALSO, a '23 Pete should have good lights.
    Oh and before I forget, the DoT does NOT approve lights, it is the manufacturer or the branding company that makes the claim that it meets the SAE requirements. Most of these lights are junk and are not legal because they produce light scatter which will blind everyone. SO be warned.
    tscottme Thanks this.
  9. Rugerfan
    Rugerfan Road Train Member
    7,010
    33,631
    May 3, 2011
    Redding,CA
    I drive a woreout 2013 and it has LED lights and has 0 issues
    D.Tibbitt and Oxbow Thank this.
  10. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Your talking about Paccar, they suck
    FLHT Thanks this.
  11. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Stock headlights are either Halogen or HID.
    The wiring will be fine if you upgrade to aftermarket LED. Not much out there for the new hood, yet.
    Parameters will need changed for them to function correctly. VECU with throw faults.
