If I was to remove the mufflers and run flex pipe in their place would this be ok? I have standard 5 inch pipes and don't want it loud but want free up the flow. It's my budget way of doing it before paying for free flow mufflers . Any ideas ? Yes / No?
Replacing mufflers with flex pipe. Yes or no ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by seabring, Nov 15, 2012.
Page 1 of 3
yea u can...but its goin to be loud.
kw9's rock and RedPete95 Thank this. -
You can buy ten foot lengths of five inch aluminized pipe cheaper than good flex pipe would cost. Walker, Stemco and other exhaust suppliers have it in their catalogs.
kw9's rock Thanks this. -
An acert is not very loud at all when straight piped. But I wouldn't use flex pipe all bent around in place of the mufflers. In the Kenworth forum I posted some pics of how I did mine. Didn't use anything other than what was already there and maybe a foot of flex pipe to join up everything to make it work. You will need a welder to weld the down/y-pipe back together. It will need to be shortened about four inches. I never noticed mine was straight piped until I put the BD tuner on it, now it has a drone/resonance that is annoying and I am trying to figure out how to eliminate that without causing a restriction.
Forgot about your muffler style and location. Tight radius elbows are available to piece together in place of the muffler.
a good welder can weld your pipe's together. i took 2 90deg. elbows and made a 180deg with a donaldson muffler underneath my w900L works great. and cheaper than PP's under cab setup.
Thanks for the responses guys. I will look into what I can do next time I am home. One place I called in Winnipeg said they will sell me mufflers that they will cut the baffling out of first but don't know if I want to pay for something then have it cut up. Will try to get some pipe and do it cheaply. I picked up 0.5 mpg after putting new air filters on the canisters so would hope to get a bit more improvement on the mpg if I can eeliminate the mufflers as well. Just don't want it too loud , don't want to be attracting the wrong attention without the mufflers .
does the law require trucks to have mufflers? would the d.o.t. fine you or shut you down if you do not have one ?
I have heard that Colorado will write tickets for no mufflers.
Page 1 of 3
