I'm replacing the Maxi brakes on my truck.
I took them off a while back and did brakes and S cams and the seals on the rears and all that stuff so now I'm finishing up and putting my brake cans on and new slack adjusters.
My truck only has two Maxi brakes on the front rear. As I'm looking at them and measuring them to cut the rod for the new cans, I see one is longer than the other one.
One measures 2 7/8 in and one measures 4 in.
Do I just cut the new ones at 4 in and see how everything works out? Why would they do something like that?
Replacing brake cans/ Rod length
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Aug 4, 2019.
Make them both the same length. Make sure the operating range does not go less than the 90 degree slack to pushrod angle.
It is common for inexperienced to mis- measure pushrod length when replacing a complete chamber. If the mechanical park spring is broken and lodged and the chamber will not go full travel an incorrect measurment is easy to screw up.
All the more important to replace brake parts across an axle.stayinback, Rideandrepair and Dino soar Thank this. -
If your replacing slack adjusters also, there should be instructions and a s-cam adjuster card with them. Usually , the card snaps onto the slack adjuster pins and the Clevis should be adjusted to where the card lines up to the center of your s-cam shaft. With the park spring released.
stayinback and spsauerland Thank this. -
I thought the proper length/ angle was 90 degrees,when brakes are applied. Wrong? Is it 90 degrees without brakes applied? Did I read @Goodysnap correct?
The angle should not exceed a right angle with brakes applied.
Best to follow the template with the slack provider as @Working2party suggested.Working2party and Rideandrepair Thank this. -
Probably has Meritor s-cam brackets, so by using their BSAP method distance should 2 3/4" + or - 1/8".
Heavyd, Working2party, Rideandrepair and 1 other person Thank this. -
Goodysnap Thanks this.
Many slack adjuster need the pushrod long enough to push the slack adjuster a-little past the 90 deg mark. (With the slack adjuster /bake shoes backed all the way off) That is so it can catch the next lug to adjust up.
When everything is properly adjusted and the brakes are set, the slack adjuster to chamber pushrod should not break the 90 as stated before.Goodysnap and Rideandrepair Thank this.
