Replacing 2 batteries instead of 4?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MTMAUS, Mar 28, 2021.
  1. MTMAUS
    MTMAUS Light Load Member
    222
    175
    Sep 28, 2019
    I was always told this was a bad idea, but it was always told to me by the person selling the batteries.
    I have 4 batteries on my truck, 2 of them are bad (can smell them) and tested bad on the load tester but the other 2 test fine and seem good.
    Is it a bad idea to just change out the bad ones?
    The 2 good ones are about 18 months old
    FYI I am in Australia where batteries are about $220 AUD ($170 USD) so a bit more expensive than in the USA
    If you do just change 2, does placement matter?
  3. mitrucker
    mitrucker Road Train Member
    5,145
    8,816
    Dec 15, 2010
    Lapeer, MI
    I would change them all. You’re in Australia, don’t you guys go out into the middle of nowhere at times? Why run the risk of having a problem?
  4. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    ^^^^^^^^X2
    Vampire, Shawn2130 and JoeyJunk Thank this.
  5. 201
    201 Road Train Member
    12,058
    24,619
    Apr 16, 2014
    high plains colorado
    Hello mate, nice to see that's just not an American attitude, but there is some merit to that. A battery can short out, and you may not know it, but it drains the good ones. Replacing just 2 is like taking a shower, and putting dirty underwear back on ( turning them inside out, doesn't count) You'll ruin the new ones in short order. BTW, I always got along fine with 3 batteries.
    Vampire, Shawn2130, JoeyJunk and 2 others Thank this.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Charge them all up. Disconnect them. Wait over night. Check voltage on each battery. If they are all exactly identical (probably 12.60 volts) then you’re good.
    If the old ones are less than the new ones, they’ll cause a situation where the new ones are effectively charging the old ones constantly and they’ll all drain down over some period of time.
    Shawn2130, JoeyJunk and Goodysnap Thank this.
  7. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    I'm gonna disagree with the parts changers on this one. If they test good why not get some more life out of them? Mark the dates so you know thier age so you can retest them on your next PM.
    While their is a certain amout of relibility from changing all four, they never all fail at the same time. When my dad was running his Pete and I was running the shop and keeping it up, the battery on main cables would always fail first. Sometimes at a rate of 3 to 1 of the other 3. I started rotating an older battery to the main cables and putting a new on on the other end. He was running a inverter for the fridge. These were Interstates.
  8. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    I have 2 banks of 2. I've always tested with load test and hydrometer every year and rotate out what doesn't pass like Goodysnap said. I have noticed that the one battery my inverter (Battery 3) was connected to went first. My inverter runs fridge and microwave. One time battery 3 was shorted, I found a silver dollar sized spot on the bottom of the battery where the plastic case melted.
    I have recently heard of testers that can reveal how much cranking amps are left in a battery, looking into that.
    Shawn2130 and Goodysnap Thank this.
  9. AModelCat
    154,578
    Typically a battery group is only as strong as its weakest battery. Personally I would do all 4 unless the remaining batteries are relatively new. I normally don't run batteries longer than 3 years in anything I own either.
    bzinger, Shawn2130 and Heavyd Thank this.
  10. AModelCat
    154,578
    Those digital testers are trash IMO. I haven't found a test method yet that beats the tried and true carbon pile load test.
    Shawn2130, Heavyd and Goodysnap Thank this.
  11. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    The midtronics capacitance type testers are very temperamental and depend highly on a good clamp to battery connection at the battery post, specifically the lead of the post. Clamping to the threads on a group 31 will not yield an accurate test because its stainless. False fails are very common when connections are poor. Like everthing else the tool is greatly depended on the user to follow instructions.
    I agree it is hard to beat the old carbon pile. Pretty reliable......
