The original batteries on my 2015 seem to be toast. They don’t hold charge long at all. I have 4. They are Exide Extreme group 31’s, 925 CCA, 180 reserve.
I’m going to pull, clean and test this weekend.
My question, anyone running the dual purpose RV deep cells (starting and cycling) in your trucks? I’m wondering if they’d be a better idea than regular starting batteries.
Replacement batteries
Discussion in 'Volvo Forum' started by 86scotty, Oct 27, 2018.
We run 8 Northstar AGM batteries which are advertised as being able to deep cycle, also run as starters.
4 1150CCA each for starter, 4 for electric APU.
AGM are less susceptible to temperature changes & are more consistent in overall discharge somewhat like the comparison between NiCad/NiMH and the newer Lithium Ion/Polymer.
Had 2 of the starters get the unique AGM rotten egg smell a couple weeks ago & changed out; funny never had any issues until it went to Freightliner for a recall and overhead...
If you stick with traditional flooded, maybe you can insulate wrap to prevent extreme temp swings and provide more consistent performance, also helps in winter time to have your diesel heater tied in with your truck coolant so you can keep the entire block warm & ease starting.WhyDriveTruck and KB3MMX Thank this. -
There is no such thing as a battery that will serve multiple purposes with equal efficiency.
An SLI (Starting,lights, ignition)flooded cell battery, the most common configuration in class 8 trucks, case size 31 with 800-1000 cca(cold cranking amps) does what it is intended to do. Start the truck until the alternator can provide the electricity for the other loads. What they don't do well is low amperage drains(Hotel loads) while the truck is off, drivers using various electrical devices for a period of time.
AGM(absorbed glass mat) batteries can be configured for SLI purposes, or for deep cycle or some combination of both. They cost at least twice as much. The combo deep cycle/SLI types don't do either very well, and in my experience were not worth the extra expense.
Flooded cell and AGM batteries have 2 different sets of charging requirements, and most truck alternators are set up for flooded cell, by far the most common battery in use. If deep cycle AGM types are used they have to be isolated and charged with a different controller. All possible of course, but more complicated.Otr Traveler, KB3MMX, sirjeff and 1 other person Thank this. -
Lead acid batteries work just fine. And have been around forever.
Temps don't bother them. When fully charged their freeze point is minus 60. Google it.
Today's lead batteries seem to be much better quality then yesterday's also. It's been years since I had to buy a battery for my car. And my last 2 were owned for 6 years each. Sold them both with the same battery they came with.
19 years driving and I've only had ONE company that actually had power to plug the trucks in. But the coldest we get is zero degrees. Maybe a few spots that would see single negatives. -
Duracell AGM batteries from SAM'S CLUB will work much better then OEM. I do OTR and use a lot hotel loads. Fridge, computer, TV, coffee maker. Two years warranty with no question replacement.
KB3MMX Thanks this. -
Thanks guys. To clear things up I'm very familiar with AGM and not interested in buying four of them. I've used them for years in camper builds and rebuilds I've done. What I'm meaning is the lead acid dual purpose I've seen for a year or two out there. They are supposedly designed for RVs. To be clear I'll be buying lead acid for my tractor. It stays at home plugged in when I'm home for more than a day or two. I'm hoping to improve it's ability to run my inverter (fridge is all that stays on when truck is off), everything else is used when truck or APU are on.
SLI31MDP - Duracell Ultra BCI Group 31M Dual Purpose (Starting/Cycling) Marine & RV Battery at Batteries Plus Bulbs
Or these if I just go with standard:
SLI31SHP - Duracell Ultra BCI Group 31 High CCA Starting Heavy Duty Battery (Stud Terminals) at Batteries Plus Bulbs
I've had great luck with these Duracells from Batteries Plus. They are lead acid of course made by East Penn/Deka.
My other options in the same ballpark pricewise are Traveller group 31 from Tractor Supply (made by Exide I think) or Rural King's Exide group 31. Their core charge is only $12 vs. everyone elses $25 or more which almost buys me about half a battery right there if I just keep my old ones to use around the house or sell on Craigslist. -
I had Tech replace one of 4 batteries do to one was smoking and got hot after it was replaced tech also tested all other batteries and they passed after few days I noticed my bunker heater showing warning every 10-30 min low voltage 12.9 to 12.7 and truck start little bit harder then before is it because new battery with old battery don't mix and I should of just replaced all 4
KB3MMX Thanks this.
