Replaced coolant now codes won't clear dash 2013 Cascadia with DD15 engine
Discussion in 'Freightliner Forum' started by concdriver, Jul 11, 2017.
  1. concdriver
    concdriver Bobtail Member
    46
    13
    May 19, 2012
    cambridge,on
    So I was replacing the coolant on my truck when CEL and Stop Engine light came on with fault code ECU 01 and Spn 111 and Fail 19 which most of you probably know if for low coolant level or bad coolant sensor. After coolant was topped up, Check Engine Light and Stop Engine Light both cleared but the dash is still showing ECU 01 Fail 19 etc. My guess is the faults have cleared but the codes are stored in memory and that is what is showing on dash. Can anyone please confirm or deny this. Should I absolutely take it to a shop to get the codes cleared or will it clear by itself?. How long should it take. Truck is freightliner Cascadia 2013 with DD15 engine. Thanks in advance
  3. Rrts247
    Rrts247 Light Load Member
    75
    45
    Feb 12, 2017
    My 2010 has to go thru full cycle, start, release parking brake, press and release clutch, press brake pedal, set parking brake.
    D.Tibbitt and concdriver Thank this.
  4. austinmike
    85,856
    If the check eng. and stop eng. lites are off and the truck runs ok, I;'d drive it. Mines got a couple faults all the time.
    concdriver Thanks this.
  5. rottwolf64
    rottwolf64 Bobtail Member
    9
    10
    Apr 30, 2016
    The dd15 I had did the same thing, fault code still shows up but the coolant is good
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Usually after three successful starts with no fresh codes, then they will clear themselves.
  7. concdriver
    46
    13
    May 19, 2012
    cambridge,on
    The fault codes did clear on my truck as well. It took about 5 days / 2000 miles / app a dozen successful starts but they are gone. thanks for the input guys
    9017 and RocketyMan Thank this.
  8. Toomie22
    Toomie22 Bobtail Member
    Hello you guys I have a 2012 cascadia an my coolant level is full but there is codes I already replaced coolant sensor but while I was driving the stop engine light came on how to clear it
  9. Toomie22
    Hello guys got 2012 cascadia i replaced coolant sensor an it’s full of coolant while I was driving check engine light came on an stop engine light started blinking engine shut off an censor is new came someone help me with problem please
  10. uncleal13
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    If it is a bad sensor. You can just leave it unplugged. The yellow check engine light will stay on, but you will not get the red shut down.
    If it still happens with the sensor unplugged, then it’s not the sensor.
    armo Thanks this.
  11. concdriver
    46
    13
    May 19, 2012
    cambridge,on
    The connector to the sensor is probably the issue.
