Repair air line with brass nipple and hose clamps?
Discussion in 'Peterbilt Forum' started by csmith1281, Nov 16, 2018.
  1. csmith1281
    csmith1281 Medium Load Member
    446
    266
    May 29, 2017
    Atlanta, GA
    I have an airline with an abrasion from an adjacent rubber hose. It looks like a main airline, black and orange, going to my rear end underneath the cab. Is it OK to repair airlines with brass couplings and hose clamps?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    As long as it is not an actual brake line.
  4. AModelCat
    154,360
    I wouldn't recommend it. Use the proper DOT compression fittings for that kind of thing.
    csmith1281 Thanks this.
  5. csmith1281
    446
    266
    May 29, 2017
    Atlanta, GA
    OK… So that is a thing? There is a fitting I can use instead of having to replace the whole line? I would much rather do something like that myself than pay for 500 at the dealership.
  6. Ridgeline
    22,108
    113,241
    Go to any dealership and have them sell you the fittings. you can get a length of tubing and cut the section out and put in the little splice.
    AModelCat Thanks this.
  7. csmith1281
    446
    266
    May 29, 2017
    Atlanta, GA
    Yup, I called them, and that’s exactly what they said. $6-$8 for the fittings, and I’m sure the tubing is dirt cheap.
  8. Nothereoften
    Nothereoften Light Load Member
    261
    265
    Oct 6, 2018
    Buy the brass, cut the broken airline. Have 2 crescent wrenches with you, don't wreck the ferrel as they're one time use only so only tighten everything once.
