I thought I read a post on here that some guys rent their flatbed. I assume that you would have to have your own tarps and straps and chains. It seems like it would be expensive to get started with a flatbed for that reason. Is it about the same price to rent a flat as rent a van trailer?
I have experience pulling flatbed loads of Steel and pipe, and I used to run a low bed hauling construction equipment, but I would have to understand better how to secure odd loads, and I have basically zero experience with tarping. So I have a few questions.
Do you need to have a headache rack when you first start out? Can anyone give me a basic idea of what the cost would be for an initial setup of straps chains and tarps? Do you go off the road often to deliver (I really don't want to beat my truck up)? I live in southeast Pennsylvania if that matters. How are your wait times to unload, detention, and TONU as compared to Van trailer work? Is flatbed good all year or is it more seasonal?
I have heard some guys say that flatbed work is so much better and pays better than van work they would never go back.
I'm considering it.
Renting a flatbed
Discussion in 'Flatbed Trucking Forum' started by Dino soar, Jan 28, 2019.
Page 1 of 4
Headache racks are required when there is no headboard on the front of your trailer.It takes a certain kind of driver to pull a flatbed.You have to be willing to go the extra mile to make sure your load is secure.Tarping is tricky especially if you have heavy tarps,but when everything is said and done,you can stand back and look at your load and say man,that's a beautiful thing,all wrapped up like a present.I used to haul overlength steel, coils and a lot of lumber.When I first started,I mainly drove cabovers with a lot of space between the front of the trailer and the headache rack. That way you could hang it over the front of the trailer instead of the back.I almost always pulled a stretch. If I had 60-65' beams I would open the trailer to 55 or 60' respectively, hang 3'off the front and 2' off the back. Those were my favorite loads 3 or 4 heavy beams in the center low to the deck.Then you have loads that are all different shapes and sizes that you really have to use your head to place them and secure them.I've hauled a lot of pipe also and it can be very tricky. I have a Merritt headache rack in my barn.It has a locking center box that goes from top to bottom,chain racks on both sides with boxes underneath and flaps that fold over to lock your binders and chains securely.It also has a tarp rack welded on top. New it would cost somewhere in the neighborhood of 2500,I got it used for a lot less from a hand was tired of skateboards.You should have at least 6 -10 chains and binders and 20 or so straps. Sliding straps on the trailer are ideal and 10 of those would come in handy.Dunnage is also very important and a lot of guys like to strap it to the deck, I always slid mine in by the landing gear and under the deck.You should also have some carpet or rubber strips to put on sharp edges and corners to protect your tarps.Tarps cost a lot,so you want to protect them.The best ones are the lightest ones. If I ever saw a mudflap on the road or parking lot I'd pick it up and use it as protection.I still have quite a collection,lol.A good pair of coveralls is also good to have,keeps your street clothes clean.Good sturdy gloves and hiking boots also are handy.I'm sure I left some things out and I'm sure you'll get some more info.It's not easy but people that have been doing it awhile can sure make it look that way.I did it for about 12yrs and being large it hasn't been very good to my knees and back,but then neither has lumping.If you get into it and you enjoy it, you'll have a lot of fun, I know I did. Good luck, any more questions, just ask.I just looked back and saw your from Pa, I made a whole lot of money hauling out of Bethlehem , Camp Hill and Allentown, also a lot of bagged mulch and soils from the mushroom farms.A lot of shingles and wallboard out of Maryland and plywood from Ga on up to Va, going to NYC and to the Amish.
.I hauled a load of 80$ a sheet plywood to the Justice dept in DC one time,they make benches for Immigration courts in the basement, what a racket they got.That's also a good story but I said enuff.Last edited: Jan 28, 2019
Reason for edit: Add-on -
No bulkhead? Don’t forget to use a penalty strapkylefitzy, silver dollar, Humblepie and 3 others Thank this. -
Bean Jr. Thanks this.
jamespmack and snowman_w900 Thank this.
A headboard or headache rack won't help much with a 40k coil coming at you. Your best off keeping it from moving in the first place.
And bean is right neither is required anymore.kylefitzy, Rubber duck kw, Humblepie and 3 others Thank this. -
I'm sure you wouldn't give out bad info on purpose but the greenhorns will take an old hands advice as gospel. That isn't always a good thing. -
TPC21, Sirscrapntruckalot, Ruthless and 3 others Thank this.
Page 1 of 4
