Removing tractor mud flaps?
Discussion in 'Heavy Haul Trucking Forum' started by Dino soar, Mar 5, 2024.
  1. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    Thank you guys for all the help. Our lowbed is up and running and we have our farm tags and everything is working out great.
    Now when I picked up the lowbed, I had to slide the fifth wheel all the way completely to the end for the mud flaps not to hit.
    So is it legal for me to run without the mud flaps? I can buy another set that I can reconfigure things to move forward, but do I need to do that?
  3. skallagrime
    skallagrime Road Train Member
    3,836
    9,880
    Apr 10, 2012
    Indiana
    Technically legal, but the second youre bobtail, in violation (so dont ever take it to a shop without the trailer)
    Rearmost tires are the only ones that require mudflaps
    BUT, if youre doing farm and a lowboy, youre going to spit more dirt everywhere with no flaps... so i would figure out what needs done to have them on the tractor
    Bean Jr., gentleroger, TX2Day and 2 others Thank this.
  4. Dino soar
    4,789
    26,858
    Dec 8, 2017
    Thank you that is a very good answer.
    Bean Jr. and skallagrime Thank this.
  5. SmallPackage
    5,278
    16,463
    Dec 20, 2019
    Marion Texas
    @skallagrime answered correctly. I will add this. Carry the flaps with you. Dot likes that. That way they know when you drop the trailer you will make it bobtail legal.
    This is where the old school Betts spring type removable hangers come in handy.
    TX2Day, Oxbow, W923 and 2 others Thank this.
  6. 062
    062 Road Train Member
    6,143
    33,166
    Oct 20, 2013
  7. beastr123
    beastr123 Road Train Member
    2,803
    22,846
    Jan 2, 2014
    Moose Jaw SK CAN
    wow a Betts kit with reflectors and bolts at a almost reasonable price.
    Consider picking up a second set of brackets to mount ahead of your drives if you have room.
    They can also be mounted unobtrusively on the neck of your trailer.
  8. stwik
    166,082
  9. TX2Day
    TX2Day Medium Load Member
    613
    4,096
    Apr 24, 2023
    Texas
    I was hunting for how close to your rear drives you mud flaps need to be. Didn't find that information but did copy and paste all of this:
    The Mudflap Rule
    One question that seems to get asked a lot is “Where are the mudflap rules?” This is especially true after someone receives a ticket for not having one!
    The FMCSA recommends mud flaps be mounted at 300 mm and at angle greater than 22 degrees.
    Most jurisdictions simply state that the vehicle must have mudflaps/splashguards on the rear of the vehicle that are adequate to keep spray and debris tossed up by the tires from hitting the windshields of following traffic.
    Specific requirements
    There are some states that provide specific requirements, and these are the ones that “set the standards” that interstate trucks need to follow. The most common requirements are that the mudflap/splashguard cover the full width of the tire and:
    • Reach to within 8 inches of the ground (AZ, DE, MO, and TX are examples). Several states say the mudflap/splashguard must be within 10 inches of the ground.
    • Extend down from the top of the tire at least the same distance as the width of the tires (MD is an example of a state that has this).
    • Cover 2/5 of the vertical tire area (MS is 2/5, several states say 1/2 to 2/3). • Be able to stop water and debris that is leaving the tire at a tangent angle of 22
    degrees or more (MI, OK, and PA all use the 22 degree standard).
    So what can an interstate carrier do? To comply everywhere, most carriers go with a standard of around no more than 6 inches from the ground, but definitely no more than 8 inches from the ground (depending on where the fleet operates). This keeps you out of trouble just about everywhere you need to go!
    Hope that was somewhat helpful.
    beastr123 and Oxbow Thank this.
  10. RockinChair
    RockinChair Road Train Member
    4,919
    12,259
    Feb 19, 2012
    CC, TX
    Is Phoenix still doing their "sailing mudflaps" thing?
  11. Northern Nomad
    Northern Nomad Light Load Member
    165
    643
    Apr 1, 2020
    The frozen north
    The truck I drive has removable mud flaps that I keep on the catwalk. The only time I put them on is when I bobtail. The mechanic made these little brackets for them on the frame and they’re secured by linchpins. On and off in seconds, as long as I remember to do it :D
