Removing Air Dryer Cartridge...
Discussion in 'Peterbilt Forum' started by Gears, Oct 22, 2010.
  1. Gears
    Gears Trucker Forum STAFF - Gone, But Not Forgotten.
    4,511
    3,184
    Aug 20, 2009
    Is there a trick or something to removing this stupid cartridge? I bought one to replace for the life of me, I can't get the one that's on there to unscrew:biggrin_25513:. Heck, it might even be the original one as far as I can tell.
    Anyone care to offer any tips or advice to getting this puppy off?:biggrin_255:
  3. jaysolomon
    jaysolomon Light Load Member
    78
    7
    Sep 17, 2010
    Take an Oil Filter wrench and put on it.
    Gears Thanks this.
  4. Gears
    4,511
    3,184
    Aug 20, 2009
    We tried pretty much everything except an oil filter wrench. I'll have to see if I can find one that big. I'm thinking it's going to take a #### tow strap!
  5. seapup
    seapup Light Load Member
    88
    15
    Aug 1, 2010
    wodstown,nj
    Actually I did that with mine. Made a makeshift strap wrench with a tow strap and a crowbar. Them buggers are tough to get apart.
  6. RW.
    RW. Heavy Load Member
    715
    995
    Jan 18, 2009
    west central IL
    You could try just pounding a screwdriver through the side of it and using it to break it loose. I've got a big pair of channellock oil filter pliers that usually do the trick: http://www.mytoolstore.com/chnnlock/oilfilt.html
    I just put the new ones on hand tight, those pliers will crush them a little where it grips.
    LBZ Thanks this.
  7. seapup
    88
    15
    Aug 1, 2010
    wodstown,nj
    He is talking about the air drier, it sits inside a solid housing. You cannot damage the housing.
  8. seapup
    88
    15
    Aug 1, 2010
    wodstown,nj
    Its also a good idea to rebuild the purge valve while its apart.
    Gears Thanks this.
  9. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    My first one I bought, I did the same thing as you. Couldn't get it off for the life of me. So I just carried the cartridge in my truck until it was time for me oil change.
    I went into Truck King in Amarillo. Told them that I needed that cartridge changed as well. They did it at no extra charge & used the same oil filter wrench that they used on my oil filter.
  10. LBZ
    LBZ Road Train Member
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    I have been looking all over for those! The Farm stores & Sears around here used to carry them, but now only stock the small ones that look like a toy in comparison to what is needed.
  11. Gears
    4,511
    3,184
    Aug 20, 2009
    Well I went out to the auto parts store and got a strap wrench that you put a ratchet on once it's on. We'll give it hell, but it'll have to wait until after a bit of football this afternoon.
    I'll keep you posted. We did punch a screwdriver through the darn thing yesterday and still can't get it to budge. Even after whacking it a few times with a hammer. I'm even more convinced that it's the original canister.
