Regarding broken cross members
Discussion in 'Questions From New Drivers' started by Seebs, Jun 18, 2015.
  1. Seebs
    Seebs Medium Load Member
    665
    271
    Mar 4, 2011
    Wanted to see if anyone else had some information here.
    My general understanding (and what I've seen in the Fed motor carrier guidelines) is that any damaged cross member on a trailer is bad.
    Got one now with three broken cross members, they're right above the tandem. The mechanic is saying because the cross members are over the tandem, the trailer is legal. Is their any exception in the guideline I'm missing or is he full of it?
  3. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,299
    Nov 8, 2009
    The Highway To Hell.
    Broken crossmembers are an OOS violation. It doesn't matter where they are. Broken crossmembers are break downs of the structural integrity of the entire trailer.
  4. joseph1135
    11,340
    27,299
    Nov 8, 2009
    That tire doesn't look so hot either......
  5. joseph1135
    11,340
    27,299
    Nov 8, 2009
    From the Tennessee DOT site:
    1. Frame or equivalent shall be of such design and strength as to correspond, at least, to standard practice for trucks of same general load characteristics which are used for highway travel.
    2. 2) Any business, corporation or person that modifies the original trailer frame shall be responsible for the performance of workmanship and materials resulting from such modifications.
    3. 3) All welding must be of electric weld.
    4. 4) Frame, cross members and body mounts shall not be cracked, broken, bent or rusted to a depth as to
      substantially weaken frame.
    5. 5) Cross members shall not be loose or missing.
    6. 6) Body mount shall not be missing, have missing bolts or rivets deteriorated or missing.
    baha Thanks this.
  6. david123abc
    david123abc Heavy Load Member
    839
    784
    Feb 2, 2011
    Augusta, GA
    I know nothing about vans, but if anything, it would seem broken crossmembers over tandems would be more dangerous.
    joseph1135 Thanks this.
  7. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Looks like heat an beat then bolt it together weld everything back in place, many DOT off. will look to see if cracks run out the end of old welds then put you oos for the smallest things?
  8. joseph1135
    11,340
    27,299
    Nov 8, 2009
    This is a true safety issue though. The crossmembers are integral to the trailer structure. When they fail, the trailer can have a catostrophic structural failure.
  9. Oldman49
    Oldman49 Medium Load Member
    353
    299
    Jul 20, 2014
    I never take advice from mechanics. These guys that are 22 yrs old, still making payments on the shing Snap On tool box with every accessory available and has his cell phone on a charging stand. Old wore down gray haired guy provides more mechanical confidence, but still DOT laws are MY expertise. Jmo..
  10. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    From the picture, it's hard to tell. I see some "bent" stuff but not anything "broken". It's an old trailer. I suspect there are probably several other issues that might put it OOS before what I see in the picture will put it OOS.
    There is no "cheap repairs" to correct that situation other then perhaps retiring the trailer out of the fleet. There are plenty of other trailers with much more dangerous damage issues on the road then that. Not knowing who your carrier/boss is, I'd say good luck refusing to pull that trailer [because of that issue] and keeping your job.
    And yes I'm very aware of the new system and CSA points and all that other stuff, so do what you want or feel the need to.
