Reefer Units: Tmo King vs. Carrier
Discussion in 'Refrigerated Trucking Forum' started by jldilley, Oct 28, 2013.
  1. jldilley
    jldilley Medium Load Member
    485
    406
    Oct 13, 2013
    Indianapolis, In
    Just as the title states, I would like to get some feedback on what unit Owner Ops prefer. Do you have a preference? Does Thermo King have more maintenance issues than Carrier or vice versa? Any information you could add to this thread would be appreciated.
  3. GITRDUN45
    GITRDUN45 Heavy Load Member
    712
    236
    Sep 30, 2013
    Good question as I'm about to buy Reefer. But way I'm looking at it is being my Truck will have TK APU firgure I get same Reefer to kill 2 birds one stone when in for maintenance. Make sense?
  4. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,138
    Jan 30, 2011
    Carrier is less expensive on parts, TK is less noisy and better put together. They both make cold good. On maintenance it doesn't matter. In fact, most dealers will do basic repairs on both brands. Unless they have a special on at a dealer, you will wisely find some independent refrigeration service that will work on them both. The apu is like maintaining a lawn mower unless you need someone to hook into the control panel for something. I get the filters from TK and do the apu myself. Any lube shop can do it too.
    GITRDUN45 and jldilley Thank this.
  5. rogueunh
    rogueunh Road Train Member
    1,082
    22,200
    Jan 4, 2011
    Doing the same thing, the TK's I've had over the years use less fuel. Other than that, they both do the job.
  6. jldilley
    485
    406
    Oct 13, 2013
    Indianapolis, In
    Sounds good. I plan on buying a Wabash trailer anyway so I don't think I have any choice but to purchase a Thermo King :biggrin_25520:
  7. Psyched
    Psyched Light Load Member
    122
    80
    Feb 22, 2013
    Us
    Laredo is a slow this time of year, you might deadhead to McAllen, lots of produce loading there.
    Saddletramp1200 Thanks this.
  8. king Q
    king Q Road Train Member
    2,880
    3,032
    Jul 26, 2010
    Johannesburg sa
    Anything with "King" in the name is obviously much better.
    Think of it , even if you go back to Egypt during the building of the pyramids with all those heavy stone blocks would you rather be a King or a carrier?
  9. jldilley
    485
    406
    Oct 13, 2013
    Indianapolis, In
    Lolz!! Point taken
  10. jldilley
    485
    406
    Oct 13, 2013
    Indianapolis, In
    Also, do compnies/agents charge the customer for fuel and pass it along to the carrier or will I pay for reefer fuel out of pocket? I run for Landstar, btw, if that makes a difference.
  11. Big Red Pete
    Big Red Pete Bobtail Member
    35
    22
    Oct 31, 2013
    Minnesota
    Always had good luck with my Thermo King. Bought my last one back in 2001 and sold it in 2008. During that time I only had it in the shop for one major repair, which was covered under warranty. I used a 50 gallon tank for reefer fuel. It gave me a lot better range for waiting to get fuel at cheaper cost. Also comes in handy during the summer when the unit is running a lot because of the heat.
