Reefer start stop or continues mode
Discussion in 'Trucker Forum Classifieds & Trading Post' started by Lookfast9, Sep 2, 2023.
  1. Lookfast9
    Lookfast9 Bobtail Member
    12
    Oct 13, 2018
    I have book load
    Broker says it’s -13 F LOAD frozen carrot on Continuous mode
    But why frozen load needs continuous mode
    can I set to start stop mode so it’s effect load ? Please advise
  3. Judge
    84,378
    used to -10 was for ice cream loads.
    no can’t do start/stop, they have temp that it’ll go down a few degrees then kick back in, other may vary from -10 to -2 continuous wants cold air continuous air
    Lookfast9 Thanks this.
  4. rollin coal
    rollin coal Road Train Member
    13,078
    25,829
    Mar 29, 2008
    TN
    If you can't afford to cover what little fuel it takes to run continuous you might be doing something wrong. What if your unit fails to restart on cycle?
    Soltaker and Lookfast9 Thank this.
  5. Lookfast9
    12
    Oct 13, 2018
    Ok set to continuous
    But broker are really cheap in now a days
  6. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,408
    Aug 28, 2009
    Airlie Beach QLd
    Summer time there bud I'd keep it on continuous run, the product will maintain its temperature provided it was loaded from the warehouse at the right temps and your reefer is run at the set temperate and maintains it constantly. For a product to remain frozen it theoretically would need to stay under 32 degrees F. Most warehouses will do a temp check on the product so it is important that you follow the instructions carefully. Where issues sometimes arise is no one bothers to do a temp check on the product when it is loaded and the poor transporter/ driver get blamed for it if the temps turn out to be warmer by the receiver.
  7. drvrtech77
    drvrtech77 Road Train Member
    13,641
    132,847
    Mar 20, 2010
    Think how expensive a frieght claim would be…
    wulfman75, Soltaker and Cattleman84 Thank this.
  8. Thrasher28
    Thrasher28 Road Train Member
    1,198
    3,307
    Aug 12, 2021
    Bowling Green, KY
    Doesn't matter whether or not it'll hurt the product. What matters is whether or not the potential temp recorder and the reefer download comes back okay if product is rejected for some reason. Maybe they rejected it for reasons not related to start/stop versus continuous, but when the reefer download shows it wasn't set correctly, it'll be your all's claim.
    Soltaker and drvrtech77 Thank this.
  9. Blagoje
    Blagoje Medium Load Member
    441
    956
    Jul 14, 2022
    Paris, Illinois
    Back when I did reefer my company had a strict rule to not use continuous mode unless a shipper or con specifically requested it in writing or had it as a posted rule when picking up or dropping off the load. Their take was that continuous mode uses too much fuel to run the reefer and sentry mode (start/stop) got the job done and used less fuel.
    bryan21384 Thanks this.
  10. dave01282000
    dave01282000 Medium Load Member
    353
    742
    Jun 16, 2021
    I would suggest to go with what's on the BOL because it's in writing.
    drvrtech77 Thanks this.
  11. bryan21384
    bryan21384 Road Train Member
    14,484
    30,973
    Sep 18, 2009
    Memphis, TN
    All brokers will say continuous for every load. I remember one told me that was company policy. When I was with another company, i ran it start stop and told the broker it was on continous. I was hauling frozen bakery products. Frozen carrots, you really don't need to run continuous. The broker will tell you one thing, but the shipper will tell you something else. Rule of thumb is you go by what the shipper/bills say when you load.
