Reefer in winter
Discussion in 'Questions To Truckers From The General Public' started by Supernaut, Feb 23, 2011.
  1. Supernaut
    Supernaut Bobtail Member
    11
    Nov 11, 2010
    Leduc, AB
    I was driving along the yellowhead one day when the temperature was about -30c (-22F) outside . I noticed a reefer trailer blowing out an exhaust plume and though, Do they actually need to do any cooling when its this cold outside? It also lead me to other thoughts. What happens in that kind of weather when you have a load that needs to stay cool but not frozen, like milk for example? Also, what happens when canned goods are transported in extreme cold? I would imagine they need to stay warm enough to not freeze and break open.
    Just curious as to how its done.
  3. rocknroll nik
    rocknroll nik High Risk Load Member
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    the reefer unit can be set at whatever temperature you need it to be at......running produce in the winter you set your reefer at the temp required to keep it fresh...anywhere from like 35-45 degrees depending on the produce. If you need to run frozen during the summer no worries just drop the temp to below zero and away you go
    Pamela1990 and bzinger Thank this.
  4. Supernaut
    11
    Nov 11, 2010
    Leduc, AB
    Does that mean it can be used as a heating unit when the outside temp is lower than your required inside temp?
    snowlauncher Thanks this.
  5. rocknroll nik
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    you got it ......it sure can......you can freeze stuff or warm it up......very rarely have I had to set the reefer warmer than 50.....and usually I only set it at 50 with a load of bulk potatoes during the coldest days in the winter
    bzinger Thanks this.
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Banana's like 60 and I'll set er around 61-62 depending on the outside temp.
    If it's that cold supernaut, I'll run the reefer even empty.
  7. SmoothShifter
    SmoothShifter Defender of the Driveline
    561
    581
    Sep 10, 2010
    Feura Bush, NY
    A reefer unit will do whatever it takes to maintain the temperature it's set at.
    It will heat a perishable load to 45 degrees if it's -22 outside. Many of today's units are sophisticated enough to even monitor the outlet air temperature so they don't freeze the top row of open produce to cool the whole load.
    For example, if you had a load of mushrooms in open flats, and the rear doors were open on an 80 degree Phoenix day, it will keep the outlet air at 35 degrees until the unit achieves set temperature instead of blasting 5 degree air out to cool it quicker.
    If this wasn't monitored, the top row of produce would have frost crystals on it, and ruin the product.
  8. Bazerk Wizz Bang!
    Bazerk Wizz Bang! Medium Load Member
    I haul not a lot but quite a bit of beer, mostly kegs but a lot of cans as well. If its -20 degrees out, the reefer is running full boar heating the beer or other beverages to usually around +38 to +40 to keep them cold but not freezing. I was always curiouse what a keg of beer freezing and blowing up would look like? Imagine it be a pretty good explosion.
    As said above. The Thermo kings we run will cool the trailer down to -20 degrees Fahrenheit, and heat them up to I think +90 degrees Fahrenheit. Goodyear tires probley all tires have to cure for a certain amount of time at somewhere around +80 fahrenheit otherwise if they get cool, it does something bad to them I dont know what, so if the factory is in a hury to get tires out they get hauled by reefer to a heated warehouse untill the curing proccess is over and they can be shipped by however means to all the customers.
  9. Maxmx701
    Maxmx701 Bobtail Member
    32
    71
    Dec 7, 2020
    So I just learned today the all temperature in a BOL are Fahrenheit unless otherwise stated. I hopes this help others new drivers :)
  10. Redneck352
    Redneck352 Bobtail Member
    So I’m wondering let’s say I set the reefer to +34 cycle mode and it for example 10 degrees outside. Will the reefer allow the load to to dip in to freezing temps before it turns on to heat it? That’s my concern. If a load bill says a range of 33-40 you can set it to cycle but it’s not supposed to freeze.
  11. Tall Mike
    Tall Mike Road Train Member
    7,245
    33,731
    Aug 20, 2014
    New York State
    No it should not let it dip that low.
    Outside temps that low I would run on continuous and make sure your fuel is treated. A froze up reefer unit is a royal pain to get started again. If you buy fuel in the southern states during winter time make sure you treat it before you get back north. That applies to both truck and trailer.
