red triangle with asterik in middle on dash 2012 freightliner cascadia
Discussion in 'Experienced Truckers' Advice' started by ozzyway, May 2, 2014.
  1. ozzyway
    ozzyway Light Load Member
    57
    Jan 16, 2014
    i dont know what this blinking light is can anyone help...
  3. s4l
    s4l Bobtail Member
    17
    12
    Jan 13, 2014
    Fort Worth, TX
    Check the owner's manual or google.. I think normally it means "Master Warning" and to check the info center if you have one.
    Midway30134 and ozzyway Thank this.
  4. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    Trl brake set but not tractor?
    ozzyway Thanks this.
  5. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Are you sure it's an asterik? I'm looking at the owners manual now and there is a flashing triangle with an exclamation point in it is the only triangle one I see. That's your ATC button you must of accidentally pushed to allow wheel slip.
    I might be looking at the wrong year. Red usually means danger. Shut the truck down until you read your owners manual.
    86scotty and ozzyway Thank this.
  6. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Condo got it. My Cassie is a 12, same atc light.
  7. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    The only time I had the red triangle with an exclamation point come on in a freightliner was a millisecond before starting to lose traction on an icy bridge. I backed off the accelerator and steered into a slight yaw and it corrected itself quickly.
    I recently had a yellow triangle with exclamation point come on when water was building up on the roadway in a heavy rain and I backed down on the speed. No issues were felt with hydroplaning.
    These are warning lights that note you have issues with traction for sure. Not sure if they also come on if you are taking a corner too fast or having a hard braking event. Back off on the speed, have plenty of following distance, and be LIGHT on the throttle.
    If these lights are blinking continuously and you think they aren't associated with traction or other driving related events, then it is likely the sensors need to be cleaned or replaced. Get it in the shop.
    Oldironfan Thanks this.
  8. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    I'd like to add that both those incidents noted above were without ATC engaged. Seems more like a warning system for the driver.
    Would like to hear back more from the OP on this.
  9. CJndaTruck
    CJndaTruck Road Train Member
    3,348
    3,364
    Nov 21, 2014
    Knoxville, TN (area)
    Not the OP but just had the same problem. It just meant that ATC has been deactivated. Hit ATC toggle and it goes away.
  10. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
    It's a roll stability warning when it comes on by itself, maybe hit a bump/dip in a corner or maybe a lil too fast. It also comes on when you disable ATC.
    If you ever want to go through something like mud and want to have full power to the wheels be sure to disable ATC. ATC will derate the motor to prevent wheel slip and not something you want to have happen when you need to hold on to your momentum.
    Lepton1 and Oldironfan Thank this.
  11. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
