Red stop engine light?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by earnies2, Apr 14, 2021.
  1. earnies2
    earnies2 Medium Load Member
    691
    281
    May 17, 2012
    Dedham, MA.
    What are some of the things to check when a stop engine light comes on in a 2012 ISX 12...
  3. Farmtractor9900
    Farmtractor9900 Light Load Member
    162
    433
    Nov 6, 2020
    Fluid levels. engine oil, coolant, alternator/water pump/AC belts.
    earnies2 Thanks this.
  4. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    Thanks I am on my way to check it out. the driver checked the fluids and said they are all ok. It has no A/C belt. I will check the altonator...thanks
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    On my DD16 Detroit. The alternator belt also drives the water pump. So the engine would get an over temperature alarm.
  6. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    This is a ISX12 the a/c belt is separate
    uncleal13 Thanks this.
  7. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Any other lights, CEL , DEF or emissions Derate.?
    Is there any low coolant warning, even though its full...... level sensor or float?
  8. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    ...just make sure gas pedal is all the way to the floor !
    Coffey and Mattflat362 Thank this.
  9. Antinomian
    Antinomian Road Train Member
    2,076
    3,241
    Feb 17, 2013
    Five replies so far and no one has mentioned checking what code(s) it threw.
    bzinger, Bean Jr. and Doealex Thank this.
  10. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Thats kinda given. Hes asking for common places to look without hooking up. Which in most cases is like sharpening a knife in the dark. A waste of time and painful.
  11. Dave_in_AZ
    369,846
    Water in the oil = stop.
    Could be just a sensor gone south too.
    Think I'd rig a jumper to bypass the sensor in the coolant surge tank first.
    I drove mine until I think it had all the emissions codes when the SCR died, and still never got the red light.
    Sniff around your coolant sensors. Eliminate those first.
    Mattflat362 and earnies2 Thank this.
