Recommended electric sleeper A/C?
Discussion in 'Ask An Owner Operator' started by TruckRunner, Oct 25, 2018.
  1. TruckRunner
    TruckRunner Heavy Load Member
    704
    3,270
    Dec 21, 2017
    I already have a sleeper heater so I may get away with just having an a/c only installed for a better price. I don't expect an electric ac to keep me cold during a summer in Phoenix but I want it to keep me cool on normal days above 80F and I can idle for the extreme weather. Thanks.
    Bean Jr. Thanks this.
  3. 77fib77
    77fib77 Road Train Member
    10,167
    62,764
    Jul 7, 2010
    St Louis
    Apu? Or if frame is long enough, side box with generator and portable ac unit in the cab . Generator on to of cat walk too. They are under $400.
  4. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    An APU or a generator with an AC unit (room or window) are about your only options. ACs pull too much power to be ran from your batteries. But you probably knew that.
  5. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    In Phoenix you need a diesel APU , trust me the electric will make you miserable in that extreme climate.
    I have the Dometic electric apu and love it but it's not for regular use in extreme temps like Phoenix.
    I'd go Carrier if you want the ability to plug into electric to run the AC system. Get the shore power option installed.
  6. TruckRunner
    704
    3,270
    Dec 21, 2017
    Yes I said I will use an electric ac for normal hot days NOT in really extreme heat like Phoenix.
    KB3MMX Thanks this.
  7. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    Just get a motel if it’s too hot. You are a rich O/O now.
    TruckRunner and RustyBolt Thank this.
  8. PE_T
    PE_T Road Train Member
    You should look into a used APU. Thermo Kings are the most popular, and they have service centers all over the nation. You can also find how to do the maintenance and some repairs on YouTube.
    New Thermo King APUs now come with DPFs, and as we all know, that is just another repair bill. I have a Thermo King Tripac APU, and does not come with a DPF. I think the Tripac Evolution would carry a DPF.
    By the way, APUs cannot handle temperatures over 90-95 F. The manual recommends to idle the truck and then turn on the APU. In extreme heat, like Phoenix, I idle my truck for 30-60 min when it is 1-2 hours from sunset. After sunset, the APU works well even if the temperature outside is over 100 F.
  9. TruckRunner
    704
    3,270
    Dec 21, 2017
    My bed is nicer than any hotel though. It's like 12 inch memory foam. I added the nicest Egyptian cotton sheets available too.
    Midnightrider909 and Tug Toy Thank this.
  10. TruckRunner
    704
    3,270
    Dec 21, 2017
    I'll never use a farting diesel apu. Most of you guys are unaware of the ParkSmart APU it worked just fine even in extreme temps and it was quiet and electric. Though I just need the ac so not sure if I want to pay the 11k for the whole system but I may have to.
  11. PE_T
    I have used the ParkSmart APU, but not enough to say how good it is, or if it’s worth it in the long run. One of the common complaints I hear about the electric APUs is that they are not practical for OTR. Electric APUs assume you will be driving every single day or not need to use it for over 10 hrs. Diesel APUs do not have these issues. Diesel APUs also means you will have electricity in your truck for a fridge, microwave, coffee maker, etc. and even protect your batteries from draining. Diesel APUs turn on when batteries are low and recharge them.
    trnowlin Thanks this.
