Can retread or recapped tires be used on tractor trailer steer tires? I know the state book says that buses it is a no no, but it says nothing about trucks?
recapped or retread tires
Discussion in 'Questions From New Drivers' started by bstrong3, Jul 21, 2015.
Page 1 of 3
OK, they can be used as a steering axle tire, legally, BUT it is not a good idea on an over the road truck. Cement Mixers, dump trucks use a wider single tire as a steering tire on heavier front axles and many use recapped tires on their steering axles. A steering axle tire on an over the road truck can be an all position or a steering tire, you should avoid putting trailer tires, even brand new, on the steering axles. I believe the regulation also addresses regrooved tires, tires that have worn down to less that 4/32ds of an inch
tread and then been regrooved to be used some more. -
You tell the examiner that you cannot have recaps on the steer axle and you must have at the minimum 4/32" tread. Recaps and regrooves are illegal on a tractor. If you have a blow out. It's almost certain death
bstrong3 Thanks this. -
Holy cow. Lol. Could you Imagine the thought in your head at all times running recaps as steers
HorseShoe Thanks this. -
average joe Thanks this.
§ 393.75: Tires.
"(e) A regrooved tire with a load-carrying capacity equal to or greater than 2,232 kg (4,920 pounds) shall not be used on the front wheels of any truck or truck tractor."
http://www.fmcsa.dot.gov/regulations/title49/section/393.75Balakov100 Thanks this. -
Caps are legal in all positions minimum 2/32 tread
Page 1 of 3
