Rebuilt my fan clutch
Discussion in 'Trucks [ Eighteen Wheelers ]' started by windsmith, Aug 12, 2012.
  1. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Well, I spent the better part of yesterday rebuilding my Horton fan clutch that was leaking air.
    The owner of the truck bought the seal kit from Fleet Pride, but I'm not sure about the cost. I do know that a rebuilt clutch runs around $600, and I'm sure the labor runs about the same. Mine had one o-ring that was torn, was spewing air and oil all over the fan and front of the engine, and the truck would not build air pressure at idle while the fan was engaged.
    The biggest challenge was removing the fan, and getting the clutch in and out in the limited space that was available. Mine is mounted to the front of a Detroit S60 in a Pete 377. It can be done without removing the radiator, but great care must be taken to avoid damaging it while performing the work. Replacing the seals will require a vise, 1 1/2" socket, T30 star bit, internal snap ring pliers, and 1/2" (I think) socket. Replacing the friction face (mine was fine so I didn't) will require a T20 star bit. Replacing the bearings will require a small arbor or hydraulic press.
    If you can spare a day, and have the mechanical ability, tools and lots of patience, it's a moderately challenging procedure that can save you quite a bit of coin in the end. I was able to do it on my own, but a helper would definitely speed the process and save you some skinned knuckles. :)
    Bigfoot62, crc32 and freightliner438 Thank this.
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    I like to put some heavy cardboard in between the rad and fan when taking one off, just in case, and for a little extra protection if something were to slip and hit the rad.
  4. Junkyard Johnney
    Junkyard Johnney Light Load Member
    209
    190
    May 27, 2012
    Plains,Mt
    Good suggestion on the cardboard, my Horton kit was around $275 so you are right about saving some bucks. One thing though, you said it was throwing oil too, this should be a dry set up, air only....kinda makes me think that you have a compressor going also and the oil swelled the oil ring in the Horton, that could start other problems as well in the rest of the system. Might have a piece of cardboard about the size of a sheet of paper hold it by a tank water drain and trip the drain slightly and see what comes out. Water , no big deal, oil not so good...
    J-J
  5. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Well, I had to do a field replacement on my purge valve last week as it had stuck open. When I did, I also replaced the filter on the water separator and found that it was full of oil and had come apart.
    This truck sat idle for about 5 years, and was only run for 240,000 miles from 1998 until 2007. As of today it has 275,000 miles. Would sitting for so long affect the compressor in such a way that it would start pumping oil? I'm not losing engine oil between changes (10K miles), so if it's pumping oil I'd think it's minimal. I think that the oil was a result of the air separator filter becoming saturated and allowing it to blow through. I believe that the filter that I changed was the original one that was shipped with the truck :|
    There was a small quantity of soupy oil that drained from my primary air tank, but the secondary tank drain was dry and clear. I kind of expect a little oil from the primary tank and in the separator. Should I look at a compressor replacement?
    I assume that your Horton kit came with bearings?
  6. Junkyard Johnney
    209
    190
    May 27, 2012
    Plains,Mt
    Yes, my kit came with bearings and all the necassary o-rings, clutch rings , front plate ect. , I would sure keep a close eye on the filter and the drain for continuing oil evidence. That sure is not much for mileage but the sitting part as you know is hard on seals. Just remember that air goes through all your brake lines to the air chambers and in the chambers themselves and all of that is rubber as well, granted it is good rubber made to stand up to moderate oil exposure but to much will eventually get those part too. It does not sound like you are pumping out oil at any great quantity or you would notice it on the stick between changes. Keep the filter fresh and a close eye on the tank drains see what happens in the next service interval. If it is still raising hell then you will be forced to do the compressor, as far as I am aware of that is the only place the air system can be introduced to oil. Do not put it off anymore than the next service interval though that is long enough to tell the story, thats your braking system there.
    If the motor does not run thats one thing, but if it does run and we can't stop that is something else entirely.....
    J-J
    windsmith Thanks this.
  7. claytonr1973
    claytonr1973 Light Load Member
    266
    289
    Jun 1, 2008
    miami,ok
    The way I do fan hubs is to remove the fan and then take a piece of pipe and lay it across the frame. On my FLD the pulley would be about 1/2 in from pipe so you could just roll the hub out. The last one I did on my truck was last fall after I tore my right shoulder up and I couldn't have done it without the pipe to help.
  8. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    When your in there it's the time to make everything user friendly.
    For my fan studs I cut them down since they were so friggin long and locktited them in there and used ss nuts with never seize on threads.
    When I had my radiator out I welded SS nuts in the channels for the radiator support. For the fan shroud I use ss bolts.
    No more stuck/broken fasteners in there for me.
  9. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Beware, when replacing the bearings on a Horton, each bearing must come out the same way or side it was installed. There is a shoulder built into the hub between the bearings. If you attempt to use a hydraulic press to remove the bearings by pushing them straight through together at one time you will sheer the hub shoulder out of the hub. Don't ask me how I know!
    Bigfoot62 Thanks this.
  10. Bigfoot62
    Bigfoot62 Light Load Member
    92
    29
    Oct 29, 2011
    Louisiana
    Question:
    Is there just a seal and bearing kit for the Horton clutch?
    My clutch plate is fine. It's just leaking a little air, and I'd just like to change the seals, along with the bearings, since they would be easy to do while it was disassembled.
    Called the local KW dealer yesterday, and the Horton "Master" rebuild kit is $380 + tax. I'd like a cheaper alternative.
    Thanks.
  11. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    I can verify this information. Don't ask me either. LOL
    bender Thanks this.
