rebuild or replace fifth wheel?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Oscar the KW, May 20, 2012.
  1. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Fifth wheel is getting sloppy, and I can't adjust the slop out of it anymore. I believe it is a Holland, has the bolt out the front. What is the cost to rebuild one, and the cost to just replace it?
  3. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    The costs are the same and you can still have wear in the plate when you rebuild one. Much better to replace these days, competition among fifth wheel providers have made prices on new units very attractive. Rebuild kits are on the expensive side.
  4. Peterbilt05
    Peterbilt05 Bobtail Member
    12
    Apr 16, 2010
    Moscow, PA
    Replace for sure, the kits to rebuild are too expensive to be considered.
  5. Don2WS
    Don2WS Medium Load Member
    306
    26
    Feb 26, 2010
    Sturtevant WI
    i had the same problem KW had the rebuilt kit for $369.95 i went to the scrap yard across the shop and bought a used one off a 2011 t660 for $485
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    SAF Holland are really former GF (George Fisher) fifth wheels. The problem is that genue kits are available on market. That's why I advice you get used Jost (37) becouse cheap, but good made in France repare kits are available for $50-100.
    GF got bolt on front. Try to ajust first.
  7. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    I have an old style fifth wheel on my 91 L9000. Instead of a pull handle, it has a lever and a safety latch. I've never hooked up to a trailer, so I have no idea how it works. This is the first time I've seen a fifth wheel without a pull handle.
  8. bender
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    You pull the lever just like you would a pull handle after you release the safety latch.
  9. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    my thing with rebuilding a 5th wheel is the liability if for some reason that 5th wheel comes loose and you lose a trailer, whos the liability gonna fall on for the damages. much safer in my opinion to replace the top plate and go on.
  10. bender
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    That's another good reason to just replace it. I don't think there's any good reason to rebuild one unless a guy just likes doing it.
  11. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    easy to rebuild, you have the yoke style. just pull the pins and flip over on a pc of plywood on your frame and rebuild in about an hour. its a excelent fith wheel. as long as the bolt is against the rubber washer it wont come unlatched.
