Rebuiiling a fan clutch
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckinjb, Jan 9, 2013.
  1. truckinjb
    truckinjb Bobtail Member
    I need to either get a Horton fan clutch rebuilt, part number 989298 or see if I can rebuild it myself. Does anyone know anyone in the northern NJ area that can rebuild it or where I can get a quality rebuild kit?
  3. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    You can get a Horton kit at any truck dealer or heavy duty truck parts supplier.
    You can also buy a rebuilt exchange unit that is ready to install.
    If you buy the kit and do the labor yourself, you'll save some money, but if you buy the kit and have a shop rebuild your existing fan hub, you won't save anything vs installing a rebuilt exchange unit, reason being the kit is expensive as well as the shop labor involved in rebuilding it.
  4. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,160
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    I was going to rebuild my old Horton clutch, but gave it up.
    I bought the bare rebuild kit, then took off the hub, but the friction disk was 2/3rds missing!
    I ended up with a low mileage one from a bone yard in Des Moines, Ia . Still using it to this date, and that was @4yrs ago. Cost was @$250 delivered IIRC.
    Just found the place:
    http://www.vanderhaags.com/index.php
    Martin
  5. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    If you end up rebuilding it your self look into kit masters they out last horton and are cheaper also consider converting to a two speed fan with there kit as well it saves a lot of wear and will give you more miles before having to rebuild it agin
  6. Ashman_42
    Ashman_42 Light Load Member
    248
    64
    Aug 14, 2011
    Kit masters part number 14-256, they handle way more torque than a stock fan clutch, 6000inch-pounds I believe, as to the 2000inch-pound stocker, and way less parts involved. Ive been using them for the past two yrs and havent had any issues.
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    +1 for kit masters. That's what we use. Much simpler design and they give good instructions. We haven'tany issues with them.
  8. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    +1 more for Kit Masters (Sounds like a cowboy name). They also have many videos on how to do the rebuild on youtube. Some Horton fans can be tough though and you may need a shop to do the work.
  9. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    When i did mine it was cheaper to just buy the hole rebuilt hub.
