Rear diff started leaking. How stop it ?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mhyn, Jul 20, 2019.
  1. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    Rear axle started leaking. The diff oil is coming out between carrier and axle housing. it was no leaking this morning. I am in Kingman area and I need to get KC and back. Any idea how I can stop or slow down this leak ? it's one drop in 3-4 minute. TIA
  3. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
    Black RTV silicone sealant. The black stuff is supposed to be more (resilient?) to oil. even if you have to lay out a bead and let it dry and stuff it in the crack with a screwdriver, try to clean the oil off and re-seal it again.
    Not a fix, but good enough to slow the leak in my experience.
    Maybe rubbing a bar of soap on it will plug it up...
    Rideandrepair, Hulld and mhyn Thank this.
  4. LoneRanger
    LoneRanger Road Train Member
    3,661
    9,445
    Jun 3, 2018
    I’m 80 miles away if you need anything bud, car and all tools ready to go.
  5. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    I was thinking to stop at Walmart and buy flexseal spray..
    Rideandrepair, Hulld and skellr Thank this.
  6. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    Thank You . I have tools with me.
    Rideandrepair Thanks this.
  7. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    As long as you clean surcease real good with carb or brake cleaner, flex seal will seal anything
  8. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    I have never used it on truck.
  9. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Just keep it full until you get home and fix it right. Gear lube is cheap. Anything you slather on top of the area with oil leaking out continuously will not bond.
    Rideandrepair, wore out and El turbo Thank this.
  10. skellr
    8,737
    12,184
    Jul 17, 2011
    How big is the puddle on the ground in the morning?
    Larger than a dinner plate? If, so you probably want to check it mid-day or so.
    I'm sure DOT has different ideas.
  11. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    do you know how many gallons of gear oil take Meritor axles ?
