Rear cab work lights
Discussion in 'Freightliner Forum' started by Detriot6.2, May 28, 2018.
  1. Detriot6.2
    Detriot6.2 Bobtail Member
    5
    4
    May 27, 2018
    The rear cab lights on the 2017 cascadia i drive shut off when you release the park brake. I would like to be able to turn them on at night to check teailer while moving.anyone know where the air switch is that controls this or is it computer controlled.
  3. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,521
    May 28, 2015
    If they're like my 16.. you can only turn them ON at a stop.
    When you reach about 5-8mph they turn OFF automatically.
    BUT...
    If it's like mine.. because I put amber LEDs in mine bc it's purdy.. once they turn off, just flip the switch OFF/ON again(while moving) and it will illuminate in motion.
    Then you can check it anytime while you're going down the highway u til you turn off the ignition to kill the sequence.
  4. Xirtam2k
    Xirtam2k Bobtail Member
    4
    Oct 23, 2023
    U guys know what's the fuse number... I found the fuse box but have no idea which is the fuse for the cab work lights
  5. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    Xirtam2k the work or utility lights might be over current protected by the SAMCAB and not have a fuse. Look at the SAM wall chart in this link https://www.dtnaecomponents.com/Fre...DateAugust2nd2010AndNewer/SAMWallChart6_0.pdf
    I see utility light output at connector X3 pin 7. (X3/7) which is a logic controlled output that is unfused but will turn off in case of over current. The utility light ground looks to be on connector X3 pin 21.
    QUALITYTRUCK Thanks this.
