rear axle on tandem tilted???
Discussion in 'International Forum' started by ttompetty, Feb 24, 2013.
  1. ttompetty
    ttompetty Bobtail Member
    10
    lafayette, la
    i just had 2 rear ends put in my truck, the first drive axle sits flat to the frame.. the second one (rear) is tilted slightly,, not parallel with the frame.. it looks like maybee it was done intentionally for the driveshaft angle but i see the rubber boot that goes between the axle and frame.. it just dont look right,, can someone look at their tandems and see if the rear axle is tilted or flat,, 93 international 9400
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Normal. Pretty much every truck is like this. This tilt is built in so the working angle of the ujoints aren't excessive.
  4. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    Once, the factory and their engineers got it wrong. I bought a new IH short wheel base tandem sleeper in 1973. The axles were tilted back to accommodate the short drive shaft. This lowered the axle grease fill hole. In about 1979, a rear wheel bearing seized and ruined the tube. I had to buy a new axle housing. The solution was a one-inch pipe elbow in each fill hole to raise the grease level which flows out the axle tubes to the wheel bearings.
  5. McKeon TRK
    McKeon TRK Bobtail Member
    18
    Feb 26, 2013
    Heavyd is right but if you aren't sure post a pic.
  6. ttompetty
    10
    lafayette, la
    ok, its probably normal, just a small amount of tilt,, just being sure,, thanks all
