Rate Confirmation Load Weight VS Actual Load Weight?
Discussion in 'Ask An Owner Operator' started by PE_T, Mar 11, 2019.
Page 1 of 4
If everything else lines up and I’m not overweight I take it. It does tick me off sometimes though.
If you needed more for the load then you’ve got a good argument.
I always tell the broker and they’re usually like “....and?”Tb0n3, Dino soar, Rideandrepair and 1 other person Thank this. -
If booked as a full TL I always let them know "for future reference", maybe my way of being upset, & passive aggressive..
If I booked as partial LTL, I tell them the extra weight blew my other load, (even if it didn't, I still want more cash) & now I have to cancel one of the loads. They generally cough up another $100-$200 to keep their freight on your truck in an LTL situation..Tug Toy, Opendeckin, Farmerbob1 and 6 others Thank this. -
And if the load is 5000#'s less than the rate con do you tell the broker you will need a new rate con for less money?
dan31186, Joetro, Dave_in_AZ and 6 others Thank this. -
I'll let em know it's lighter than advertized after I get loaded, but a rate reduction.?, get lost. Not even a broker is dumb enough to ask for that.. Its their fault for not researching the freight they asked you to move. That's why they pay when they are wrong, either way..Tb0n3 Thanks this. -
So hauling more weight than posted is stealing from you but hauling less for the same rate is OK? Kind of one way logic.
Humblepie, larry2903, Long FLD and 1 other person Thank this. -
singlescrewshaker Thanks this.
Do you charge a lower rate if a load is 35k net vs 40k net in initial negotiation?Humblepie, singlescrewshaker, larry2903 and 1 other person Thank this. -
How much lower is your cost on a lighter load that you are willing to haul for a lower rate on a 35k load vs a 40k load? Work those numbers out.Humblepie, singlescrewshaker and PE_T Thank this.
Page 1 of 4
