Rate Comparison: Asset Based Broker vs Non Asset Based Broker
Discussion in 'Ask An Owner Operator' started by Renegade92, Jan 10, 2023.
  1. Renegade92
    Renegade92 Light Load Member
    108
    113
    Oct 2, 2019
    Texas
    To all the Owner Operators out there, from your experience, when it comes to comparing rates from an "asset based" broker (company owns the equipment, and employs company-drivers), to those of a "non asset based" broker (company doesn't own equipment, and employs Owner Operators; example, Arrive Logistics), typically what is the trend? Are the rates typically higher or lower?
  3. Siinman
    Siinman Road Train Member
    5,158
    12,909
    Mar 5, 2017
    Kansas City, MO.
    It all depends on when it needs to be there along with supply and demand of the trucks around. All will pay out the butt if need be.
    Renegade92 Thanks this.
  4. Ridgeline
    22,101
    113,190
    Are you confusing a broker with a carrier?
    Renegade92 and Siinman Thank this.
  5. Renegade92
    108
    113
    Oct 2, 2019
    Texas
    I don't think so. My definition of carrier, is the party who actually owns the equipment that the freight is moving on. Therefore, a non asset based carrier can't exist, because they don't own any equipment. In other words, while a broker can also be the carrier (asset based), a broker can also just be a broker (non asset based).
    BUT, as you have forced me to think about this question more, I now realize that anybody who drives for an asset based carrier would have to be a company driver, as they would be driving company owned equipment, hence the "asset based". As such, they would not have access to load rates.
    So, while I would still like to know how rates compare when it comes to asset based vs non asset based, I likely will not get an answer. The only person that would know would be somebody that worked specifically as a broker for an asset based broker, while also having had worked with a non asset based broker either as a broker or an OO. Likely, hard to find.
    I started this thread, because I was curious to know if asset based brokers would typically be able to charge customers higher rates due to the special value that they have to offer, in the form of using their own equipment and drivers. If I was a customer, I would be more comfortable knowing and controlling who exactly is moving my property. That is something that only an asset based broker can offer. Whereas, a non asset based broker has to rely on a "network" of carriers; essentially equipment owned and operated by strangers.
    I was also curious to see, if asset based brokers were charging more than non asset based brokers, since they actually own the equipment being used, and have to cover those associated expenses.
    Thanks, you just killed this thread. LOL.
  6. Long FLD
    Long FLD Road Train Member
    11,354
    45,708
    Mar 4, 2015
    If they have equipment and drivers they are a motor carrier. That’s what he’s trying to tell you. An asset based broker doesn’t exist. Yes the trucking company can have a brokerage for their overflow but those rates will differ from what their trucking company gets paid on their contracts. Anything being brokered out would be closer to spot market rate than it would be to their contract rate. And that works both ways. For example last year any carrier putting their overflow on the load board was probably moving those loads at a loss to them because spot rates were higher than contract rates. Now it’s the other way around. So they can get those loads moved cheaper than their contract rate.
    Siinman and Renegade92 Thank this.
  7. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    Before MAP-21 asset based brokers meant the same MC# for both the brokerage and the carrier.
    After MAP-21 you can not get both under the same numbers, any before that were grandfathered in
    The term now is light asset based if one number a brokerage and another a carrier
    Non asset if they don't have a carrier#
    Before you could set up with a customer under one authority, now you have to set up under both numbers or take the load through
    the brokerage and "broker" it to your carrier#.
    Long FLD, Siinman and Renegade92 Thank this.
  8. Renegade92
    108
    113
    Oct 2, 2019
    Texas
    Ok. Lets clarify. Lets forget about the terms I was using. Lets start over.
    There are carriers, who own their own equipment, and who are dealing directly with customers.
    There are brokers, who do not own their own equipment, and who serve as an intermediary between carriers and customers.
    Is that correct?
    What had thrown me off, was reading an article, in which the founders of Arrive Logistics, referred to themselves as: "Today they’re among the top 40 non-asset-based freight brokerages in the country" (Arrive Logistics Achieves 100% Revenue Growth in 2016 - Arrive Logistics). By using the term "non asset based freight brokerage", they imply that the term "asset based freight brokerage" exists. Neither term is correct.
    They are speaking incorrectly, as the only 2 terms that are correct, are brokers and carriers. And they, Arrive, are simply a broker. They do not own any equipment, so they are not a carrier. Just a broker. None of this "non asset based freight brokerage" BS.
    How the hell a pair of 25 year olds back in 2013, who probably had no CDL or experience in logistics, manage to pull something as big as Arrive Logistics off, while years later, still ignorantly getting the industry terminology wrong, is FUBAR. If you can explain that one to me, that would be appreciated.
  9. Siinman
    5,158
    12,909
    Mar 5, 2017
    Kansas City, MO.
    They are known as a back haul cheap company from my experience. Never seen them pay anything worth moving. At least was nice anytime I have talked to them but that's it.
  10. wichris
    4,243
    8,447
    Jan 17, 2011
    When you're a brokerage only, the correct term is non asset based.
    When you're a brokerage and a carrier under different numbers the correct term is light asset based
    When you're a broker and a carrier under the same number the correct term is asset based.
  11. Midwest Trucker
    5,871
    21,124
    Aug 31, 2018
    Man, I’d say brokers who also run trucks definitely have better rates overal in general. These non asset brokers really are all profit driven while asset based are more customer focused driven and don’t have to make every penny on each load. As myself an asset based company who brokers, we definitely pay above market share and like to use repeat carriers as much as possible. It does suck sometimes as non asset tries to muscle in. Happens a lot.
