So I was finally able to swing by Tarpstop in Gary IN during business hours and picked up some Durabilt ratchet binders. I haven't found anyplace else that sells a 3/8" binder rated for 6600# without going to a 3/8-1/2", which is way too big for me.
Anyways, I've never used these before. You can really keep pulling on that handle like its nothing can't you? I was a little worried I'd damage my trailer if I kept on pulling. Is that possible?
Ratchet binders
Discussion in 'Flatbed Trucking Forum' started by Freightlinerbob, Jul 12, 2014.
Page 1 of 3
I use them all the time and never had an issue with the truck or trailer but have crushed a few wire baskets, a couple of pieces of what is called Check Aid Material and a "bucket" that is used to pour molten metal.
I never use an extension, I watched another driver use an extension and broke a chain. -
I put a couple notches in a stake pocket from a chain... I have binders rated at 7700lbs. They are the heavy duty binders for 3/8 & 5/16
They better then them ******* snap binders. Save your limbs from getting wacked.
Like the others; never used a cheater on one, never damaged trailer but did have to be careful not to crush something I was chaining down but overall loved me some ratchet binders vs chain brakes (breaks?) ok chain binders. Good investment is a couple cans of spray grease for the threads and ratchet. I liked red grease. It was a lithium grease and did a better job and didn't gunk up like black grease does. WD-40 did more harm than good because the grease keeps the surface rust that causes sticking from forming. WD-40 doesn't do good at that and if you spray WD-40 it will melt away the grease. Only time I used WD-40 on my ratchet binders was to clean out gunked up grease that had gotten thick and useless. Used WD-40 to clean off old grease, then sprayed fresh grease and worked everything til smooth. Spray "Brake Cleaner" also works VERY well at getting caked up gunk outta the threads and ratchet. Evaporates too so not nearly the residue that WD-40 leaves. Did use WD-40 to break a sticky one free, then sprayed red grease. Plus it has a little plastic tube like WD-40 does so you can the grease right where you want it. Grease over WD-40 for my ratchets worked real well for me. Motor oil works too but Lord it's messy.
I use a good synthetic water proof grease on mine, I found that not only does this work well in all kinds of weather, it really makes them work better. I get some on these assignments that get "stuck" and I have to actually break them loose with an extension. Poorly maintained@!@#@!!$
Synthetic Water Resistant Grease - Amsoil GWR3P-EA -
Yup the synthetic stuff is a tad more expensive but totally worth it. Especially if you can keep the same binders and thus can keep up with them staying free and easy. I loved the spray because it has the delivery like WD-40 which is totally cool but is actually grease which is awesome.
As far as trapping grit; IMO the negligible grit it does trap (I can't disagree with that; grease DOES keep particulates in it - til they get worked to surface to surface then they get get crushed) is put under such pressure that it powderizes to a point that it doesn't do perceptible damage to that hardened steel due to abrasion which is what they are saying. It's a binder - not a crank or cam. The steel is much harder than the grit. Does it do "damage"? Sure. But the damage it does is the same as normal wear and tear from doing it's job as a high tension binder with moving parts and does NOT shorten tool life any more than normal wear and tear does; so I'm with ya on that. You'd have to put a handful of sand directly into the threads and ratchet to do that. -
I've snapped a 5/16 chain and broke a stake pocket with one of them Durabilts. Never talk to someone while you're ratcheting lol
BigJls1 and Freightlinerbob Thank this. -
Have you ever tried gear lube(as what you would put in your steer axles)? Does not wash out of the threads when it rains/snows and lasts longer than spray on lubricants.
Page 1 of 3
