I've been having issues with the Ranco end dump I pull for about a year.
Tailgate has never fully raised and now it won't raise at all, unless you're driving about 15 miles per hour for about an ⅛ of a mile, and the latches also now have a mind of their own!
They used to immediately unlatch when I flipped the switch but now it might take 5 minutes or it might take 15 minutes, but today it really threw me a curve.
I was hauling dirt/rock to the dump, backed up, stopped, hit the tailgate switch and nothing- which has been the norm for the last few weeks.
After about 10 minutes the latches unlocked so I got back in the cab and raised the trailer up and nothing came out. I got out and looked and the latches had locked, on their own, with the switch still flipped to open.
Any suggestions?
Ranco end dump question
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by dedmunne, Feb 24, 2022.
How are they operated, hydolic- pneumatic-piston?
Daycabinit and Keepforgettingmypassword Thank this.
I pulled a Ranco half-round about 20 years ago, and at one point I was driving down I-35 when my latches opened and my tailgate lifted all the way up. Good thing I was empty! The mechanic went through it and said there was an electrical short that had caused the malfunction, so that might be what you're dealing with.
Keepforgettingmypassword Thanks this. -
Switch
Air can
Collapsed air line
is it trailer or is the truck not letting enough air over?
really not a hard system to go through -
If they are air it can often be the valves are leaking or not flipping or perhaps there is a short in some of the wires.
I once found someone had nicked one of the control wires during the install and covered it with tape but as you can see below it finally corroded enough that the pilot valve wasn't get enough power to flip the piston reliably.
There are so many things it could be that really the only way to figure it out is to trouble shoot it with a multi meter etc...
This is especially true because it eventually works. Heck once I found that the exhaust port mufflers on the pneumatic cylinders were plugged, with would make the gate stick both down and up for a random amount of time.
Luckily the systems are quite simple if you take the time to understand them but intermittent issues always require lots of troubleshooting and remember to check voltages and consider adding pressure gauges as you troubleshoot.
