RAM 3500 vs 5500. What is the biggest difference?
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by MisterX, Jun 12, 2014.
  1. MisterX
    MisterX Bobtail Member
    Hello fellow drivers!
    I am a new O/O and am looking at purchasing RAM truck, but I am stuck between Laramie 5500 and 3500 and don’t know which one will be the best fit for me. Dealers say that 5500 is a truly heavy duty truck and will perform better, but when I look at all the features, I get a little confused. They both are 4x4 and will have 6.7 cummins and AISIN heavy duty transmission. The only big difference I see between 3500 and 5500 is the payload and axle. Payload in 5500 is twice as much compared to 3500 and axle is 4.88 compared to 4.10. But maximum towing capacity is the same on both trucks, 3500 has more horse powers with the same engine (cant figure out why is that) and 5500 will of course be less fuel efficient. What other differences do you see between these two models that I might not get? Which vehicle would you recommend? I will be using this truck for car hauling.
    Thanks everyone!
  3. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,842
    Jul 28, 2011
    Glasco,Ks.
    Differences are mainly frame, rear axle cap. and tire cap. other than that it's a wash. A 5500 will not 'PULL' any more than a 3500 (given the same gear), but the will "haul" more payload.
    LGarrison and daddy2twins Thank this.
  4. Ziggy319
    Ziggy319 Medium Load Member
    540
    638
    Mar 27, 2012
    Syracuse,ny
    I believe that the tires brakes and other suspension components are all bigger.
    Hammer166 Thanks this.
  5. milskired
    milskired Road Train Member
    3,829
    1,401
    Jul 20, 2007
    Plainfield, IL
    Rims should be a 19.5 on the 5500 and not sure about the 3500 but its not a 19.5. Usually that is because of the bigger brakes on it. The rear end should be a Dana 110 which is much larger then the 80 that comes in the 3500. Yeah it has one low gear in the rear end and 75 MPH will be about your top speed. As for the motor being less HP then the 3500, it is because Dodge knows it is going to be put to some serious use and abused. Ford did the same thing with the Powerstroke, it is de tuned on the 450 and 550 trucks for longevity. They also may have the same towing capacity but look at the GVWR, the 550 is going to be a lot more then the 3500.
  6. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    I'd go buy a nice single axle class 8 truck and save yourself about $25,000 to $30,000 in startup costs and it will out pull both of the trucks you're looking at.
  7. KANSAS TRANSIT
    4,080
    6,842
    Jul 28, 2011
    Glasco,Ks.
    AND, have a "REAL" bed to sleep in!
  8. Big Duker
    Big Duker "Don Cheto"
    2,921
    2,867
    Sep 18, 2007
    Weatherford, TX
    Either way still junk. Get a real truck like SHO-TYME suggested.
    24kHotshot, Hammer166 and SLANT6 Thank this.
  9. SLANT6
    SLANT6 Road Train Member
    1,094
    1,376
    Dec 3, 2012
    The Nut House
    Why does everybody want to buy a pickup truck and then claim they are in the TRUCKING BUSINESS? I don't get it. It is the equivalent of getting your Boy Scout First Aid Badge and the showing up at the Medical Center wanting to perform surgery.
    WWF1970, pavrom, Big Duker and 3 others Thank this.
  10. SHO-TYME
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    They all think it's cheaper, but they'll spend $50,000, drive it for 3 years and find out it's worth $10,000 now, especially after they've went through 2 transmissions, and the motor now needs to be rebuilt. (Yes, a few have gotten more out of them, but not everyone does.)
    Or they think they can get by without having to have a CDL. If you're hauling vehicles, you have to be really careful to stay under 26K. Buy the signel axle, license it for 55,000 lbs and run your butt off and you won't have to worry about being overweight.
    Here's a shocker, Oil and fuel filters cost more for my 6.0 Ford than the same filters for my 3406E CAT.
  11. king Q
    king Q Road Train Member
    2,880
    3,032
    Jul 26, 2010
    Johannesburg sa
    Anyone know what sort of fuel usage difference will there be between using a light single axle class 8 correctly spec'd vs a heavy spec'd pick up?
    Assume running 70-75mph range.
