Ram 3500 dually 6.7 diesel engine Turbo problem
Discussion in 'Expediter and Hot Shot Trucking Forum' started by wecihi, Jun 3, 2020.
  1. wecihi
    wecihi Bobtail Member
    6
    6
    Oct 7, 2018
    I have Ram 3500 dually 6.7 diesel engine and noise coming from Turbo when up to 20psi on turbo , i went to official ram service and they said it's waste gate on turbo and I'm okay for now untill check engine light come on but if i want the fix it right now they have to change whole turbo ( 5500$ ) they said.
    I do not get it and not trusted , is not possible the change just the waste gate ?
    Thank you.
  3. 51.50
    51.50 Heavy Load Member
    895
    1,942
    Jan 20, 2016
    Salem Oregon
    Find a turbo specialist shop and ask them.
    Lite bug Thanks this.
  4. Ol'Shusquatch
    Ol'Shusquatch Light Load Member
    234
    1,920
    Jul 8, 2019
    BC Interior
    Suggest that if it is not on warranty to stay away from the stealers. The majority of these pickup sellers are not staffed with any real proficient diesel engine techies. That was my experience with Ford before and now that I have one of these Cummins, I will be staying away from RAM shops when warranty is off.
    There are many well experienced light duty diesel guys around and I would be surprised if you couldn't save a massive amount of money. 5500 sounds like robbery, IMHO
    wecihi, Lite bug and 51.50 Thank this.
  5. Brandonpdx
    Brandonpdx Road Train Member
    4,184
    3,972
    Dec 27, 2007
    Elkhart, IN
    You should go sign up at one of the Ram forums and ask them first (or try the search maybe)
    Dodge Cummins Diesel Forum
    My hunch is that you could probably find a good used one for $500 on Ebay and install it yourself, but I'm not a Ram guy so IDK for sure.
    wecihi Thanks this.
  6. Lantraxco
    Lantraxco Bobtail Member
    26
    17
    Jun 10, 2020
    Coming in late, I am not sure on the newer 6.7's but on the earlier versions, 2007.5 and forward, there is no wastegate, there is an electronic actuator that changes the variable geometry of the turbo. When in doubt, take it to Cummins, they'll sort it.
  7. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    980
    2,580
    Sep 15, 2011
    Cibolo,Texas
    Find a diesel performance shop.
