Rain flap on exhaust is dinging like crazy!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by freightlinerman, May 18, 2013.
  1. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    I just put a new stack and rain flap on my 5" exhaust, this is for a Series 60. At low idle, it goes *DING DING DING DING DING*, the flap gets blown up and lands down, then blown up and down, etc. The ding results from metal hitting metal. The process repeats itself and results in about 80 dings a minute. Fast idle is not as bad but still annoying, only when you drive or go full throttle does it stop. How would I counteract this? Put weights on the flap? Or weights on one side? Please help, this is annoying.
  3. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    What did you expect when you installed it? I guess I'd probably pinch the hinge or tack weld it to hold the flap open, but it'll still block out most rain and weather. Or just remove the flapper.
  4. Diesel Dave
    8,516
    23,380
    Jan 20, 2010
    Hesperia, Ca.
    Flap's are old school. I havn't seen one in ages. I run straights(no flaps) and when I park it and I think it's going to rain, I put a pair of bucket's on top.
  5. eeb
    731
    268
    Mar 24, 2013
    As long as you're not letting it set for months on end during the rainy season, I wouldn't even worry about the buckets, unless you just want to. Might get a little sooty splatter out of the pipe when you fire it up after a rain, but nothing worth worrying about.
  6. x#1
    x#1 Road Train Member
    1,773
    1,104
    Dec 24, 2009
    Cherokee County, Alabama
    rain flaps! wow those are indeed old school.idle it up driver! i vividly recall the rain flaps flapping on all the old mechanical engined trucks.the noise would even superceed a defrosting reefer unit at times.thanks for jogging my memory-
  7. SimD
    SimD Light Load Member
    148
    30
    Dec 23, 2012
    dallas, tx
    The ones I have they have a lil plastic in them, so everytime they come down they hit plastic So no metal to metal contact which equals no noise. So try adding a plastic piece or somethibg
  8. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    amd the plastic doesnt melt?
    get brittle crack
    all a waste of time nowadays
  9. 123456
    123456 Road Train Member
    10,555
    5,745
    Oct 22, 2010
    32179
    never heard of rain flaps.
    I HAVE heard of rain caps !
  10. Floyd
    Floyd Light Load Member
    163
    25
    Jun 1, 2010
    Central Maine
    Like most have said.........rain caps aren't a necessity unless the truck is parked for a long period of time.........keeps the rain water from getting in there, pooling in a low spot and eventually rots a hole in your exhaust pipe.
    On the other hand, if your shut down overnight, it rains, then you restart the next morning it will blow black water and soot out the stack and all over anything in the vicinity.......including someone elses truck. And anyone whose tried, knows that stuff does not wash off easy.
    If you would like to keep the rain caps, and quit the dinging, you can weld some counterweight to the back of the cap. Try mechanics wire to temporarily hold the counterweight until you find just the right amount. Once you find just the right balance of weight, weld it on permanently.
  11. peterd
    peterd Medium Load Member
    349
    365
    Jan 7, 2012
    St.Catharines ON
    Trucks with diesel particle filters have no soot in pipes to blow out after a rain.
