I have a Radio Shack TRC-448 and when I am on AM the static is loud but when I change to LSB or USB I can not hear any static until I turn the volume all the way up and even then it is not very loud.
Is this normal for this radio?
Radio Shack TRC-448 CB Radio low SSB and USB Static
Discussion in 'CB Radio Forum' started by don4444, Dec 29, 2018.
Since this radio was made between 1977 & 1982, it probably needs all the electrolytic capacitors replaced. Then have an alignment done on the receive section of the radio.
This is a common problem, there are three transistors (two are for the product detector and the other is the audio preamp before the audio amp and speaker).
Most likely the audio preamp transistor is bad.
This is a common problem. -
Thanks -
Q217 is the preamp but you have to check if the product detectors are working. -
Thanks
