Radio has constant crackle and squeele?
Discussion in 'CB Radio Forum' started by jrscott1970, Aug 5, 2016.
  1. jrscott1970
    jrscott1970 Light Load Member
    53
    24
    Apr 24, 2015
    Setup: 2015 and 2016 Coronado
    Cobra 29BT and a 148
    Stock antennas on 2016
    Francis on 2015
    Radios, both do the same thing in both trucks. Different mics. The transmission has crackling, the reception has crackling , breaks up, and squeeling. It appears to be worse when vehicle is in motion . Changed power cables. Even tested it with a cig lighter power cable to rule out internal cb power wires. Antennas on both trucks are tight, not cracked, swrs seem fine. I'm thinking short or bad ground somewhere, but the fact that it does it on both trucks, has me stumped as to where to look.
    Thank you for any help.
  3. Bout Z
    Bout Z Light Load Member
    275
    1,149
    Mar 14, 2015
    so. ohio
    Something in the antenna system. Coax or antenna shorted to ground would be my first guess... try a new piece of coax directly from the radio, to the antenna
  4. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Does it vary with rpm when parked? Does they still have them same issues when the engine and all other accessories are powered down?
  5. rabbiporkchop
    9,681
    6,537
    Feb 9, 2012
    Wapwallopen, Pa
    Check this with an ohmmeter and get back to us..
    Reason for edit: Pic
  6. bored silly
    bored silly Road Train Member
    2,714
    656
    Jul 1, 2016
    just got rid of that problem yesterday finally the 2015/2016 trucks have the cb and stereo system tied into each other. that crackling and squeal you hear is actually because.if you listen closely when you transmit your cb is going thru the stereo speakers aka 6x9 up top. I grounded everything on truck. but the short of it is. go buy the cobra s500 ext.speaker turn the talk back crap on speaker off. push the noise cancelling button in. its really really bad if you run a radio with a built in amp in it. I run either my magnum s980 with a 300 watt amp under its belly or I switch and run my galaxy 98 v. with a amp under its belly. I went thru hell getting rid of that problem. do not cut off that red wire off the back of that ext.speaker repeat do not cut the red wire in the back of that ext. speaker. leave it intact.
    rabbiporkchop Thanks this.
  7. bored silly
    2,714
    656
    Jul 1, 2016
    and so you perfectionists and you know who u/r . the red wire is for a ear plug for the driver if he's running team. which I don't do because I'm not going to prison for killing some idiot .
  8. Ridgeline
    22,599
    119,963
    Ok here lets do a couple troubleshooting questions before we assume something.
    First is this ... When you listened to the radios, did you have the truck running?
    Second ... What does the crackling sound like? I know this can be a stupid question but there are different sounds.
    Third .... Does the crackling on receive happen when the squelch is turned up or the rf gain turned down?
    Fourth .... When transmitting, is the mic gain all the way up (don't remember if the 148 has a mic gain) and if it doesn't is the mic a power mic?
    And more important question that I should have asked right from the start is this, has either these radios been modified or messed with like a peak and tune job?
    jrscott1970 and rabbiporkchop Thank this.
  9. bored silly
    2,714
    656
    Jul 1, 2016
    and I know what everyone is thinking just shut off the stereo. it makes no difference your cb is always going to come thru the door and 6x9 speakers. my truck has no visible cb antennas on it factory I mean. the factory antenna is up in the top back of the cab .real dumb ### who came up with that crap !!!!!!!
  10. rabbiporkchop
    9,681
    6,537
    Feb 9, 2012
    Wapwallopen, Pa
    I disconnected the factory stereo system in all of the Volvos that I used to drive and that solved my problem since I don't use a stereo to begin with
    bored silly Thanks this.
  11. bored silly
    2,714
    656
    Jul 1, 2016
    here's the kicker with this setup per freightliner themselves aerodynamics----it just makes me feel so good inside to know how much fuel I'm saving because those two whip antennas are not out there blowing in the wind
    Neverready and rabbiporkchop Thank this.
