Radiator Flush
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sgreer78, Jun 22, 2009.
  1. sgreer78
    sgreer78 Light Load Member
    251
    62
    Jul 26, 2008
    St Louis, MO
    Does anyone do theirs themselves? My truck is running hot, 200º-225º and the truck wasn't well maintained before I bought it so I'm sure it needs to be done. The shops in town want around 350.00 to do this. Money is tight and anything I do myself I will.
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    A flush probably won't drop your temp, just improve the chemical quality. If it is due for a flush and you want to do it your self remember to be environmentally responsible and dispose of the old antifreeze legally! Check to see if there is dirt packed in between the cooling fins of the rad core, air-to-air, and or the A/C condenser. If there is you will need to power-wash the dirt out. We see this quite commonly.
  4. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    hose it out from the engine side to the front
  5. 05chopper
    05chopper Light Load Member
    169
    22
    Dec 25, 2008
    USA
    Yes cleaning the outside is very important I start out with shop air to blow out dirt then finish off with low-pressure water.The inside of the radiator can be chemical cleaned with caterpillar 30 day flush! This cat flush does a nice job while you drive.Do not go any longer than 30 days with this flush.After flush then remove t-stats make sure there is no corrosion in the seats where the t-stats ride.Also check fan operation you could need more blades plus fan belt tension. Some times the water pump can slip on the shaft if its a cat!What engine and type of cab do you have?
    Baack Thanks this.
  6. sgreer78
    251
    62
    Jul 26, 2008
    St Louis, MO
    S60 Detroit, FL Columbia 120
  7. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Never heard of the Cat flush stuff, sounds like a good product, I will definitely tell the service department!
  8. 05chopper
    169
    22
    Dec 25, 2008
    USA
    If you can look inside the radiator look for deposits they look white. This 30 day flush will shine the inside the stuff smells like rotten eggs.Also forgot do the easy things first check your dash gauge with a known good gauge.I use infrared gun to check the degree of temp split between the upper and lower radiator plus the t-stat for opening and closing.
  9. FYDA FREIGHTLINER CINCY
    FYDA FREIGHTLINER CINCY Light Load Member
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    u can also use tide or cascade soap to clean the cooling system.. only use the powder kind. do not use liquid it makes a big mess. cascade is very good if u have oil in the coolant. when u are flushing and cleaning the system, make sure engine gets hot enough to turn fan on. fill with water add a half a cup of cascade run engine till fan comes on 2 times and drain water repeat till water is clear. then run clean water through it again till u get all the soap out
    FireTrucker Thanks this.
