Radiator drain hose
Discussion in 'Volvo Forum' started by mmmmmmm, Aug 24, 2019.
  1. mmmmmmm
    mmmmmmm Bobtail Member
    Can I just make radiator drain hose with a brass quick release coupler and a piece of hose
  3. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
  4. 86scotty
    86scotty Road Train Member
    4,376
    11,619
    Aug 27, 2017
    Appalachia
    Yes but double check the size. I was looking at my radiator the other day and it looks bigger, maybe 3/4"? Any Volvo shop will know.
  5. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,210
    Feb 25, 2016
    I-20 LOUISIANA
    Yea idk probably so. Because the VOLVO brand part is like $70
  6. 86scotty
    4,376
    11,619
    Aug 27, 2017
    Appalachia
    No way I'd pay that. I just so happen to rent a parking spot from an industrial fittings supplier. The back door is always open when they're open. I'll drop by and ask them what it is because I need one too. I'll let you know but it may be a few days.
    What cracks me up though is that Volvo gets a bad wrap for stuff like this but lots of times their stuff is cheaper than anyone else. I bought 75w-90 gear oil to do my rear diffs a couple weeks ago. Volvo sold me 5 gallon jugs for around $115 apiece when Fleetpride wanted north of $150.
  7. Mudman78
    Mudman78 Light Load Member
    106
    108
    May 23, 2016
    The Volvo drain hose is part # 9996049 and it's $78.87
    The coupler size may be proprietary though as it has the Volvo part number stamped into it.
    86scotty Thanks this.
  8. 86scotty
    4,376
    11,619
    Aug 27, 2017
    Appalachia
    Doesn't it thread on to the bottom of the radiator though? Couldn't you just change the whole fitting?
  9. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Don't even try!. Fitting is molded in plastic.
    Fitting diameter is 3/4. I use garden hose and phillips screwdriver to push valve. The other end of the hose in plastic container from walmart with lid. To fill system apply deflate end of the pump for inflatable mattress to the top, push screwdriver and coolant going back.
  10. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    I believe it’s a special fitting you can find it online for much cheaper easy to break but if you don’t use it everyday I don’t need best quality.
  11. jaylo
    jaylo Bobtail Member
    21
    18
    Jan 30, 2010
    wichita,ks
    86scotty and HopeOverMope Thank this.
