Radiator 4 row vs 3 row
Discussion in 'Volvo Forum' started by waltherz, Jul 4, 2017.
  1. waltherz
    waltherz Light Load Member
    133
    13
    Dec 12, 2012
    I have a volvo 04 with volvo engine 465, have to replace the radiator and i'm considering replace the original 3 row for one of 4 row, someone know if could work better on summer?
    Thanks for any opinions
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    If your truck is less than 600hp A new 3 row will be all you need, if your old rad was worn out that is?
  4. waltherz
    133
    13
    Dec 12, 2012
    is leaking, thank you for your opinion.
  5. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    i always go with the biggest radiator available, better to have a bigger radiator than you need than to overheat if your changing it anyway
    KB3MMX and cnsper Thank this.
  6. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Go with volvo oem if everything working properly as far as fan and thermostat 3 rows is more than enough
    KB3MMX and waltherz Thank this.
  7. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Four row only way to go
  8. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    "Bigger" isn't always better.. be careful if you go 4 row .. some aftermarket can actually lose flow and cooling capacity compared to OEM.
    Rad thickness also effects this.... Thicker not always better.. Reduced airflow
    REMEMBER... OEMs spend millions on the R&D
  9. Volvo8873
    Volvo8873 Light Load Member
    239
    145
    Apr 27, 2016
    Western Wisconsin
    And buy Volvo OEM. The aftermarket ones are really crap.
    KB3MMX Thanks this.
  10. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,210
    Feb 25, 2016
    I-20 LOUISIANA
    Any way to buy volvo oem without going through the dealership? I just hate buying parts at volvo, they find a way to put 30 on 10 on everything
