I just started with a company that runs produce from Houston to Fort Worth two times a week in a 26ft box truck.
The truck is plain white with no company name or anything on it. I asked if I would have to stop at the weigh station outside Willis, TX and they said no, which doesn’t sound right to me.
I asked if they used ELD’s or paper logs and they said no. I feel like I should keep a paper log book anyway.
My question, I’ve read that with newer trucks, you couldn’t use paper logs and *HAD* to use ELD’s, is this true?
If so, are there any apps that I could use on my iPhone? Preferably ones that aren’t overly expensive?
Thanks!
Quick question re: Box Truck and logs
Discussion in 'Trucking Industry Regulations' started by TexasTrucker83, Aug 30, 2023.
If the truck has farm tags and is under 26,001 lbs gvw no logs are required.
It doesn’t have farm plates, but that’s good to know about the 26k lbs. I believe the empty weight is 13k lbs and the load is always about 1,000lbs (organic lettuce.)
Does that apply to weigh stations as well? -
GVWR under 26,001# is non CDL.
Since it is over 10,000# you need a medical certificate.
GVWR = gross vehicle weight rating and tat's the number they go by -
You still have to stop at weigh stations even with farm tags. I am thinking they are using the agricultural exemption which can still be used even without farm tags.
You get a 150 mile radius from the source of the agricultural product that is exempt from HOS and then once you enter 150 mile radius of the destination of the product you are again exempt from HOS.
So if you are traveling less than 300 miles to reach the destination then you would not have to log anything.
They would still have to display a DOT # and the product has to be in an unaltered state from harvest.Last edited: Aug 30, 2023
Reason for edit: Forgot that you can use ag exception without farm tags -
what matters is the data plate in the door showing what the maximum
Gross weight truck was designed to be
a lot of manufacturers de rate the GVWR of the truck to be under 26,000 lbs using small tires etcwis bang Thanks this. -
prostartom Thanks this.
