Quick question about tire bead damage
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Walleye05, May 11, 2016.
  1. Walleye05
    Walleye05 Light Load Member
    68
    8
    Sep 5, 2012
    So can a tire still be used safely with a torn rubber off the bead from the shop's guy prying the tire off?
    I'm in a situation with a shop that did that to my tire and they're saying it's ok, but i say no.
  3. Prom Night Dumpster Baby
    Prom Night Dumpster Baby Medium Load Member
    646
    473
    Jan 12, 2012
    Bug Tussle, TN
    As long as the innards of the bead aren't cut or bent the worst that could happen is the lack of rubber lets air leak out.
    I'd be real pissed at the guy who butchered my tire though. Tell them at least if they won't buy you a new tire to not charge for the service they did.
    And throw in a free balance to keep their customer happy.
  4. Lyle H
    Lyle H Road Train Member
    1,289
    2,931
    Apr 16, 2014
    Well, they probably won't allow you any casing credit for it when you go to buy a new tire later.
    That should tell you something.
    ExOTR Thanks this.
  5. Walleye05
    68
    8
    Sep 5, 2012
    I'm really pissed here, they tore 3 tires. I went there to swap my winter tires back on to see if the 4 new tires i bought from them were causing the bouncing issue I've been having, it isn't the tire, they tore one of my summer tire, which they will replace at no charge. The other 2 winter tires which are virgin Michelin X One XDN2 super singles with about 50k miles on it. They are now not accepting the damage was their fault. I inspected the tire before putting it on, it was perfect. Now its torn about 3 inch wide around the bead, The inside of bead is fine just the rubber over it is torn.
    I'm just really bummed about that and concerned that it will cause a blow out when I put it back on next winter.
  6. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Drop them off at a tire recap for a repair, they can put rubber on them then put tires in their oven to make the repair last.
  7. Yves kanevil
    Yves kanevil Medium Load Member
    522
    465
    Jan 10, 2016
    Nighthawk
    Are rim flanges worn out. Usually a tire get cut when the flanges get so worn out that it cuts beads like a knife
  8. Walleye05
    68
    8
    Sep 5, 2012
    Not sure about flange damage, will have to check next time I take it off.
    I'm just going to go ahead and pick up my winter tires and have them waive the bill on labor. Then have my local retread store fix it.
