Question on the 8/2 split
Discussion in 'Questions From New Drivers' started by NewTruckerGuy, Mar 6, 2024.
  1. NewTruckerGuy
    NewTruckerGuy Bobtail Member
    29
    32
    Jan 26, 2024
    So... let's say you've been driving for 11 hours and you're out of driving time. You decide you're gonna' utilize the 8/2 split and you take your 2 hours break right now.
    Okay... 2 hours go by...
    Question #1: That extends your driving time by exactly how much? How many more hours can you drive?
    Question #2: When you finally do take the accompanying 8-hours off after you're done driving... does that reset your 14-hour clock? Or must you absolutely have 10 CONSECUTIVE hours off in order to reset the 14-hour clock?
    Thanks.
  3. bryan21384
    bryan21384 Road Train Member
    14,483
    30,974
    Sep 18, 2009
    Memphis, TN
    If you driven your entire 11 hrs, the 8/2 is useless. You need a 10 hr break. The 8/2 is only effective if you have drive time left.
    Example" you drive 5 hrs. You park 2 hrs,, so you have the same 5 hrs prior. Let's say decide to 3 hrs after you've parked for 2 hrs. Next, you'll need to be in the sleeper for 8 hrs. When your 8 hrs is up, you'll have 8 hrs to drive, because you burned 3 hrs out of your 11 previously.
  4. tscottme
    tscottme Road Train Member
    Once you use up your 11 you are done for 10 hours. 8/2 needs to happen when you stop with available hours, not AFTER you use them all up.
  5. NewTruckerGuy
    29
    32
    Jan 26, 2024
    So after this example you gave... can you do the 8/2 split again after? As in, drive a few hours again, take 2 hours, then rest for 8 hours? Or MUST you follow up an 8/2 split with a full 10-hour break?
    Is there a limit on how many 8/2 splits you can do back to back?
  6. NewTruckerGuy
    29
    32
    Jan 26, 2024
    Nevermind, I figured it out lol.
    Basically you get a ROLLING 14-hour period every time you complete the required 10-hour break (which must include at least a full 8-hours in the sleeper).
  7. JimJones
    JimJones Bobtail Member
    16
    24
    Sep 2, 2022
    No personal conveyance, I found that out the hard way.
  8. bryan21384
    14,483
    30,974
    Sep 18, 2009
    Memphis, TN
    Exactly right.
  9. kemosabi49
    10,435
    44,381
    Jan 13, 2013
    SW Arkansas
    The split break does require that the longer period, whether you do 7/3 or 8/2, be in the sleeper.
    The normal 10 hour break does not specify how many hours, if any, that you are in the sleeper. Just has to be 10 consecutive hours off duty and/ or sleeper.
    NewTruckerGuy, tscottme and lual Thank this.
  10. Fcrev
    Fcrev Bobtail Member
    9
    5
    Oct 3, 2014
    So if I'm at a shipper and I'm on my 8 hour berth period and they kick me out prior to the completion I would have to complete a full 8 hour period again to remain in compliance if I PC down the road? I'm kinda stuck in that situation now.
  11. Hatt91
    Hatt91 Light Load Member
    153
    350
    May 18, 2018
    Let's say you are 6 hours (SB) into an 8 hour split sleeper. If you PC out of the shipper, you need to complete a 10 hour in order to drive again. The 8/2 is shot. So that's 4 more hours.
