question on brake drums
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gunner76, Jun 2, 2010.
  1. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    how many sets of shoes do you run before you replace the drums. I have the airlight drums and the second set of shoes are getting close to needing replacement. Should I replace the drums too or are they ok for another set. I felt inside and they are wore down a little but not really that bad and are wore even across.
  3. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    You have to measure an inside diameter of a drum, dealers should have a tool to do it. Maximum alowed diameter can be found someplace on a drum.
  4. Floyd
    Floyd Light Load Member
    163
    25
    Jun 1, 2010
    Central Maine
    Beltrans is correct. There should be a maximum allowable diameter stamped somewhere on the drum. Usually it's just outside the pilot hole where the hub bolts on.
    If this measurement is getting close I would replace them. Problem being, that even by installing new shoes you won't get the full braking potential. The old drums are more likely to distort and your brakes will fade sooner because there isn't enough "meat" on the old drums to absorb the heat.
    Also visually inspect the drums for any heat/stress cracks.
    However, if your old drums are still well within spec and pass a good visual test then run 'em.
    Good luck, hope this helps
    Floyd
  5. gunner76
    500
    137
    Mar 11, 2010
    IA
  6. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    i usually go 2 sets to 1 drum never had a problem if the drums get too thin they can explode
  7. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    we always replace the drums every time. Their cheap, usually grooved pretty bad and cheap insurance. However we usually use pretty mean shoes so eat drums, but they stop great!
  8. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Good advice J. Brakes are not a place to be cutting corners.
  9. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    whats the going price on drums i plan to replace the ones on my dump this yr..thanks
  10. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    Just bought a pallet of them and they were $65 each American made. Got prices between $80 and $65 each depending on dealer.
