question on axle weight distribution for single axle volvo.
Discussion in 'Volvo Forum' started by Rick1234, Aug 26, 2014.
  1. Rick1234
    Rick1234 Bobtail Member
    I have a 1995 volvo single axle tractor hooked to a 27 aluminum dump trailer with which I want to haul grain. The tractor nameplate says 12,000 lbs on the front axle and 21,000 on the rear drive axle. The tractor wheel base is 152 in or 12'8", The distance between the drive axle and the first trailer axle is 18'6" and the distance between the two trailer axles is 48" (4'). I calculated that the trailer (27') can hold about 18 tons (36,000 lbs) of grain full. I estimate the trailer to weigh less than 10,000 lbs empty. I don't know how much the tractor weighs empty but a good deal of that weigh is over the front axle.
    According to the NY DOT bridge formula (W=500{(LxN/N-1)+12xN+36} I should be able to have 48,500 lbs on the rear drive axle and trailer with 34,000 lbs on the rear two axles.
    Can anyone tell me whether I am in any danger of either overloading the drive axle (exceed 21,000 lbs) or violating the rules?
    Thanks
  3. 98989
    98989 Road Train Member
    5,990
    6,740
    Sep 14, 2008
    where is 5th wheel/king pin?
    you are in pretty big danger of being overload
    my estimations are : if king pin is 0.5m from beginning of trailer you would be able to load about 33-34 000lbs
  4. mnmover
    mnmover Road Train Member
    1,237
    1,103
    Apr 5, 2009
    Lichfield MN
    Drive axle should be 20,000 lbs only, and trailer axles are not far enough from the drives to allow 34,000 lbs. unless NY has some other formula like florida does. To put 34000 on the trailer axles you must have a lot more space and a 27 foot trailer is not long enough. I would guess that your gross weight should not exceed 60,000. 12 on the steers, 20 on the drive and 28000 on the trailer. just my guess..........
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Hi. I have '01 Volvo Cabover with single axle. Fortunatly here single axle weight limit is 10 000 kg, but I cant use tandem axle trailers anyway. I tow european tridem trailer and trailers with spread axle to move load to trailer tail. But when road is slipy with ice ore snow I have many problems driving up a hill.
    Is the fifth wheel with slider?
  6. Rick1234
    Thanks for your reply, The problem here is that we are limited to 20,000 lb per axle or 9000 kg. I suspect that I cannot carry as much weight as the tandom trailer could hold and would like to estimate just how much I should limit the load. If I knew how much the tractor itself weighed I could estimate how much weight I could put on the axle. Of course there is the fact that some of the load is transferred to the front axle as well.
