Question - How much to rebuild a - 2012 Cascadia Engine -
Discussion in 'Freightliner Forum' started by JerryD13, Aug 17, 2017.
  1. JerryD13
    JerryD13 Light Load Member
    169
    126
    Oct 17, 2016
    Question - How much to rebuild a - 2012 Cascadia Engine - DD15 14.8L 455 HP
    640K on engine - DD15 14.8L 455 HP
    is there a Kit?
    what would you recommend?
    What would you not recommend?
    anyone that does good work on rebuilds?
    looking for feedback - nothing URGENT but close.
    Thanks in Advance
    Rideandrepair Thanks this.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    One of our guys just did a DD16 for $32,000 at the Western Star dealer.
    JerryD13 Thanks this.
  4. JerryD13
    169
    126
    Oct 17, 2016
    Oh Ok -- )) Thanks for the reply ........ uncleal13
  5. 10-4Peterbilt
    10-4Peterbilt Bobtail Member
    9
    8
    Aug 1, 2017
    That's crazy 32k for a rebuilt DD16 the new detroits are garbage plain and simple. If I was in your shoes I would find a good used 12.7 Series 60 and get a hold of Kustom Truck. I heard they supply all of the harnessing and electrical to convert from the DD15-16's to the old Series 60 gems in the Cascadias. Sounds like it would be a lot cheaper option than rebuilding the DD and get you a whole lot better engine at the end of the day.
    uncleal13 Thanks this.
  6. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    have done a few of them looking at about 20-25 K with head and turbo
  7. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    with these new dd engine the parts are super expensive just the overhaul kit alone you are looking at about 9000 and that is if you can even find one anywhere, last one i had to do they had one in dallas and that was all got lucky consider also about 4000 to 4500 for a head and you are #### near 13 to 15K in parts alone. that being said overhaul kit comes with everything including egr cooler and egr door and also rods unlike any other kits i have seen so far but it is still super expensive. i dont know why but from what i know a lot of shops around do not do them at all usually dealer only, beats me why an engine is an engine at the end of the day still put together with nuts and bolts.
  8. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    the head is $3000 exchange at DD dealer. not always pistons must be changed. not always camshafts must be changed...if engine has 640k miles I will change all bottom bearings, cylinders, piston rings plus gaskets, O-rings. no need to change the head at 640k miles. the head of DD15 is good designed part and last long(more than million miles).
  9. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    you can change what you want personally i do not like to take a chance and do 15 to 20k worth or work and leave the head the same there is more than one way to do it. there is a lot of cheaper ways that is up to the person but if a customer comes here and tells me to save pistons and just change rings personally i will not do the job because i can not stand behind this kind of work and will not warranty it so therefore i will not do it.
  10. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    have you read the dd15 workshop manual about pistons and rods ?
  11. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    not all the way. Just the stuff that i really needed kind of hard to find free time to read all the manuals. everybody has their own opinions. just simply expressing mine.
