Question for n14 tune to 625hp
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rasim, Nov 22, 2021.
  1. Rasim
    Rasim Light Load Member
    96
    16
    Jan 24, 2014
    I have a stock n14 red top celect plus 500 hp and 1650 torque. 9 speed 390 rears.
    can i upgrade via ecm tune to 625hp and 1850 torque without changing any parts?
    diesel doc in effingham il told me not to worry because the cpl# allows it.
    I believe my cpl number is 239?
    I appreciate your answer
  3. Rasim
    96
    16
    Jan 24, 2014
    Or should i tune to 525hp and 1850 torque?
    500hp is a lot but i believe because of the 390 rears and 9 speed i do not feel it that much.
    any suggestions?
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    i don't think there was a 625 1850 factory tune available for the n14 do you could probably get there with a non factory tune. i think 525hp 1850tq was the high end for the n14 do you have a 1850tq transmission/clutch?
  5. Rasim
    96
    16
    Jan 24, 2014
    no the clutch is 1650 not sure about the transmission but most likely the same
    Metalhead5052 Thanks this.
  6. DUNE-T
    DUNE-T Road Train Member
    6,874
    16,589
    May 10, 2015
    Detroit, MI
    525/1850 is the highest factory tune. Anything above that would be aftermarket.
    Your clutch and tranny should be fine for 1850tq, but at 2050 I think you will start getting issues.
    Even after getting the 1850 be ready for at least new turbo, because your old one won't last long, unless it was recently changed
  7. Rasim
    96
    16
    Jan 24, 2014
    What about the 650 hp aftermarket, best to avoid with my set up?
  8. DUNE-T
    6,874
    16,589
    May 10, 2015
    Detroit, MI
    I personally would until you are sure about durability of all your components. Even then, who knows what's in that tune
  9. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Absolutely do not go over 525/1850 tune unless you have spare blocks.. look up n14 block fretting. Majority of high hp tunes the blocks will crack .
  10. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Don't lug it and it'll hold up just fine. Plenty of high hp big cams running 600+ and if you don't have the NASCAR attitude it will be just fine. They have a stronger bottom end than the big cams
  11. 2013Maxx
    2013Maxx Light Load Member
    135
    42
    Jan 17, 2018
    I wouldn’t go 200ft pounds over the clutch rating. The transmission might hold up, but the clutch won’t. My truck was originally 1550 torque.. I had it bumped up to 1750.. My clutch is good for 1850 tho..
