Question about watermelons
Discussion in 'Refrigerated Trucking Forum' started by Canadianhauler21, Jul 16, 2020.
  1. Canadianhauler21
    Canadianhauler21 Heavy Load Member
    842
    1,616
    May 15, 2017
    I'm currently hauling watermelons, pulp temp at loading was 80°F. The shipper told me to set reefer temp to 55°F, it's about 6 hours later and my temp is 63°F. I'm new to hauling these kinda things so was just wondering is it normal to take long for it to cool down? Do melons spoil easy?
    Upinsmoke Thanks this.
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Yes for cool down ,no for spoil easy, get them to destination asap good luck
    Upinsmoke and Canadianhauler21 Thank this.
  4. StrokerTSi
    StrokerTSi Medium Load Member
    532
    777
    Aug 28, 2016
    Should be fine, I hauled a load of water melons 1000 miles in a vented dry van, no one questioned it.
  5. Canadianhauler21
    842
    1,616
    May 15, 2017
    Thanks for your quick response, reefer work is stressing the crap outta me.
    Looks like I shouldn't be too worried about it than, thank you.
  6. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    did you not pre cool trailer. are your corners plugged
    Canadianhauler21 and Upinsmoke Thank this.
  7. clausland
    clausland Road Train Member
    1,933
    11,067
    Dec 5, 2014
    North Woods
    Fresh produce carries a lot of field heat. Reefers are intended to maintain temps, and won't pull it down quickly. Melons aren't that temp critical, you'll be fine, as long as they weren't loaded wet. I hauled many with just a vented dry van and hay on the floor.
    Field heat loads will fret the new guy. He'll wonder why the therm aint droppin, reefer's runnin full bore. Well, it's froze up. Keep hitting the defrost cycle ever so often & keep truckin....
  8. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Don’t worry, If things go wrong you just open a road side stand......:-/
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Loaded them off the field on a 104 degree day into a vented dry van. Took the load from south of Phoenix all the way to Calgary.
    Two nights on the road, the trailer sweated pretty bad.
    When I opened the doors at Calgary, the heat inside the trailer was impressive. A couple of broken watermelons had lots of mold. Went directly into two grocery stores I stopped at.
    Some of the skids they put directly on the sales floor.
    Didn't have any problems.
  10. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,947
    3,306
    Jun 10, 2019
    You never passed one of these side-of-the-road stands selling these things? There is no reefer in the back of a 85 chevy.
  11. bad-luck
    bad-luck Road Train Member
    3,252
    5,954
    Nov 16, 2013
    Baltimore, Maryland
    Watermelons retain heat , it takes a long time to bring the temperature down. Especially since they usually are coming from the field and or a hot warehouse.
    The second questions answer is no. You han also haul them in a dry van, as long as it has a vent in the front and rear
