Question about using a trickle-charger while truck is parked (aka home time)
Discussion in 'Experienced Truckers' Advice' started by hiwaysteward, May 18, 2015.
  1. hiwaysteward
    hiwaysteward Bobtail Member
    40
    16
    May 18, 2015
    America... :)
    Hello everyone,
    My question is simple... but not simple to ask.
    We often stay in the truck over home-time, as is the case this week, because we're not at "home". We're taking care of some business and so staying in an RV park - in the truck. Easier than it sounds at first.
    In any case, there is a load on the batteries with the cab lights and other minors things. We have everything else running off shore power using an extension cord.
    My question is... there are times just like this where we can plug in... and what is the best trickle charger to use to keep from having to start the truck throughout the day, due to "Low Voltage Disconnect"?
    Would a 3Amp maintainer trickle charger work to stay up with the load from lights in the cab and minor things such as that?
    And/or... would you recommend using a trickle charger at all? If not, why not?
    Any insights into this are much appreciated as once you purchase a trickle charger you can't return it... so I don't want to leap before I've looked for answers to this question.
    Thank you!
    Andrea
  3. herbiemin
    herbiemin Light Load Member
    94
    50
    Dec 20, 2014
    I wouldn't recommend a trickle charger (usually 1-1.5 amps) but I would go with what is called a float charger. A trickle charger is just that, it puts out a low amp charge continuously. Even tho its low amp they can and will overcharge a battery if left on too long. the float charger (we have used Battery Tender brand in the past, don't know about them much anymore haven't bought one for about 5 years) will float or adjust the amps to maintain around 12-14 volts, and will shut down completely if it senses it goes over that point. Much better for the batteries.
    scottied67 Thanks this.
  4. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
    If it is your own personal truck that YOU bought, then do as you please. If it is a company truck, then ask one of the shop mechanics. If you fry any of the batteries they will go thru the system checking for a charging system problem, and if they determine you caused the problem, what do you think will happen to you then?
    I have had a Battery Tender myself, for my motorbikes, and it works well, however, it is still an electrical device that can go beserk at any time, and fry your battery..
    again., if this is your rig, bought and paid for, have you priced APU's and the tax advantages, etc,etc?
  5. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    My truck has the Volvo factory inverter that switches to a charger when plugged into shore power.
    AModelCat Thanks this.
  6. scottied67
    scottied67 Road Train Member
    10,816
    12,615
    Mar 14, 2010
    california norte
    I'd like to learn of a solution too. Have fridge, lights, GPS, TV, XM, basically every cigarette lighter plug is being uses even if the device is off it is still 'vampiring'. In the last few months I've already spent more money on jumpstarts than it would have cost to buy 6 brand new batteries lol. Most of that charge was from this nationwide place that advertises, 'you call, we show up' lol. Anyway thought I could recoup some of that by just being more careful and idling a little more etc and making the batteries last a few months longer.
    They are standard batteries and 19 months old so it is time plus they dont like being drawn down past a certain point then recharged. Previous batteries I had in there lasted 3 years and were the deep cycle variety which can be drawn down to zero charge and recharged with no damage.
    Long story short I would like an inexpensive way to float or maintain my batteries with my little 2000 honda generator-- any ideas?
  7. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
  8. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    I have solar panel changers in all of my trucks that I throw on the dash and plug into a constant power cig lighter. I never come back to dead batteries. I don't know how well they would work if your using power at the same time though.
  9. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    i don't think you'll fry the batteries with a 1 amp trickle charger. unless the truck is going to sit for a week. with 4 batteries. your talking .25 amps to each battery. and 4 batteries = 4000 amps.
    i'd get a 2/6 amp charger. and let it charge on 6 amps while sleeping. unless you have a fridge, then leave it on the entire time. maybe on the 2 amp setting.
    you'll have to figure out what you use during your wake time. and what might be needed during sleep time.
    harborfreight sells chargers cheap. and they DO refund or exchange if you want something else. so does walmart.
  10. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    Not much you can do other then buying a Xantrex Prosine 2.0. This is a smart inverter/charger/shore power unit for around $1,200. When you park at an RV park you plug the extension cord into it and it makes the switch to external power. It's also a smart 100amp battery charger that won't fry your batteries. It backs off the amps when needed and to zero when they are charged. A normal battery charger keeps going non stop until your batteries either boil, melt or start on fire.
    Chances are you are using more then a trickle charger can put out. Your batteries will slowly discharge or the trickle charger will burn up. You have 4 batteries. Your in a truck, not a car with one battery.
    I've been this route before.
    http://www.xantrex.com/power-products/inverter-chargers/prosine-2.aspx
    KenworthGuyNH, Strider and scottied67 Thank this.
