Question About The Detroit DD15 Engine
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jacker300, Apr 22, 2014.
  1. jacker300
    jacker300 Bobtail Member
    Hello, I'm new to this forum and hope to find an answer to this question. I'm interested in buying a truck with a dd15 engine, but i want to know the difference between the truck engine I have now compared to DD15. I'm currently on a truck that has the 60s series engine. Now, I want to know the fuel economy and how many miles I can go per gallon on the DD15.
    Also if someone can tell me the key differences between the 60s engine and dd15. I'd also like to know personal experiences from people who had this engine on how well it runs and if it has lots of problems or not.
    Sorry if this post is sloppy, but I just can't seem to find answers for these questions anywhere on the internet.
    Thank you for the help!
  3. slippez
    slippez Bobtail Member
    22
    4
    Apr 13, 2014
    you didn't search very hard on the net if you couldn't find any differences. mpg on the dd15 should be better then your s60, but that depends on just about everything.
  4. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    In a nutshell the DD15 will have all the emissions garbage on it....Better fuel mileage perhaps, but that 60 series will out last the DD15 hands down... The company I work for runs DD13's and they regularly need to be attended to due to emissions problems.. The pre-emissions 60 series is the way to go if you ask me...If the 60 series has a DPF then it is pretty much ruined. Oh yeah, as far as fuel mileage goes I've seen pre-emissions trucks get the same or better MPG's depending on the set-up.
  5. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    The DD15's will do better generally against any series 60 fuel wise. The 2003 and older Series 60 were the best performers. What's different about these engines? EVERYTHING. New vs old technology. Gear train, injectors, clutter on the exterior of the engine, etc. Numbers will vary, there are too many factors. But, you can generally expect 6-9 MPG with a DD15, and 6-8 with a SEries 60. Again, way too many factors, all I can say is GENERLLY a DD15 will outperform a SEries 60 in fuel economy. Longevity? Couldn't tell you, but I've seen DD15's with a million miles on them already. Today's modern engines will last around the same mileage.
  6. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    A 1 year wonder not paying for maint telling you a dd15 will outperform a 60 bs i have both side by side the maint is half the cost and when something breaks most of the time is dealer only items my 12.7 can be repaired anywhere for less money and time.....and the mpg ain,t no improvement
    Ruthless Thanks this.
  7. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    If you comparing 07 dd15 and the current dd15, I would recommend taking the current dd15.
  8. knightrider77
    knightrider77 Bobtail Member
    44
    24
    Jan 9, 2014
    columbus oh.
    All I can tell ya is I get 5.8 mpg heavy and standin on it 7.9 light load in a 2012 freightshaker with 300k on it but also have been towed to a computor to se what's wrong with it to been told don't ever run out of fuel bout everything you do gotta reset the computor
  9. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    My buddy drove a cascadia with dd15 and had 7.9 mpg at 68. Best one he had is 8.5 mpg at 63.
  10. Rocks
    Rocks Road Train Member
    14,902
    61,101
    Jan 13, 2008
    Somewhere
    I have been driving a Freightliner Cascadia, 2012 DD15... don't know more specifics about the engine right now... Having problems with the emissions system and it only happens while going up and down California mountains...
    Last Nov. while running around in CA, had problem, Freightliner in Fontana did all kinds of troubleshooting tests, said filters were all clogged up... ended up replacing SCR box, DPF filters, all sensors, and more... can't remember it all... Truck was in their shop for 3 weeks... :biggrin_2552: A few days ago, going up very steep hill on CA-58, truck started having the same problem again... :biggrin_2552: Engine lights on, noise coming from SCR box, lost power... Now truck is at Freightliner in Fontana... and they are doing the same troubleshooting all over again...
    I asked them why is this happening, what is causing it, how to prevent from happening again? And they don't know... :biggrin_25512:
    Does anybody here have any info or any experience with this kind of problem? I am really puzzled... :biggrin_2552:
    Mdtrucks2013 Thanks this.
  11. slippez
    22
    4
    Apr 13, 2014
    join the club everyone has had problems with it,it is probably a different issue, but still urea related
