Question about requesting Broker-Carrier Agreement
Discussion in 'Ask An Owner Operator' started by dis_bit, Nov 29, 2021.
  1. dis_bit
    dis_bit Bobtail Member
    18
    11
    Jan 27, 2021
    We own a truck, and operate under another company's authority. Our dispatcher has been caught once lying about the freight rate, and there has been several instances of discrepancy between what the dispatcher has described regarding shipment details and what is actually required. I won't bore with too many details, but I will say that our current shipment is requiring my driver to disassemble then reassemble a crate transporting panes of glass multiple times as this one load has several delivery locations. My driver is receiving no compensation for this labor, and the dispatcher did not advise my driver that this load would be driver assisted. If we request the carrier company send us a copy of the broker-carrier agreement, are they required to provide it? We would like to request that we receive the agreement on all future loads my driver is dispatched on. Are we allowed to do this?
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    It definitely should'nt be a problem. If it is then it will be a problem. Everything should be written down ahead of time. It will help when that moment comes of "I don't recall". As far as your driver enough of that doing work for free.
    I was hit with that driver assist one time. They were paying lumpers to unload and they wanted me to assist for free. If I don't help they wouldn't unload it. I said it won't be unloaded. The broker asked what did I want to help. The same you are paying them. That was that.
    dis_bit Thanks this.
  4. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    Who ever is paying you, should provide you with the Rate Confirmation. This confirmation has the details of the load. Which include driver responsibilities and the load pay.
    Good luck
  5. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Why are you not paying your driver for his work?
    Not his problem you made a bad deal for your company......
    You should be throwing in money for the unload.
    And companies wonder why there is a 100% turnover in this industry...
    ibcalm19 Thanks this.
  6. dis_bit
    18
    11
    Jan 27, 2021
    Thanks for the responses so far... To elaborate - we own a truck, but my father, the driver, currently operates it under another company's authority. This other company has assigned our truck to "Bob," who is the one accepting the loads and dispatching our truck. "Bob" does provide my father, the driver, with the rate confirmation; however, time after time, when my dad arrives to pick up the load or deliver the load, the load details on the rate confirmation do not represent the reality of the job. We want the broker-carrier agreements, the whole contract, between "Bob" and the broker, so we can determine whether it is "Bob," the various brokers, or the shippers who are misrepresenting.
    "Bob" has been caught out, once, absolutely lying about a freight rate on a rate con before. The company my dad is currently driving his truck for takes 12% from the rate provided to the driver. My father took a load that "Bob" sent a rate con stating was sold at $4200. When my dad arrived to pick up the load, the shipper happened to ask my dad what the rate con was. When my dad said $4200, the shipper laughed and literally pulled out his phone and dialed the broker on speaker RIGHT THERE, asked the broker what the job sold for, and my dad heard from the horse's mouth the the rate was actually $8400. When he called "Bob" to ask WTF, "Bob" feigned ignorance then refused to send the broker-carrier agreement. When pressed, "Bob" corrected the rate con, tried to blame it on the broker, then on the factoring company, before finally just refusing to discuss it at all. Like, if it is brought up, he hangs up the phone.
    Speed_Drums Thanks this.
  7. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,601
    Nov 11, 2020
    I would ask for a written rate con on every load.
  8. keebler13579
    keebler13579 Heavy Load Member
    910
    1,757
    Nov 16, 2012
    Sounds like its time to find a new carrier
    Dino soar, Speed_Drums and Ruthless Thank this.
  9. dis_bit
    18
    11
    Jan 27, 2021
    We have less than a month until my dad has the one year experience pulling a step deck required by the company we want to apply to... That said, if ya'll have carriers you'd recommend, I'm all ears. We do have hazmat qual.
    *** edit to add: my dad has 10+ years pulling dry van, and several years pulling tank, belly dump, and other equip for the oil fields. He has a great record.
  10. Ridgeline
    22,108
    113,241
    The first thing that needs to be asked is this
    what does your contract say about accessorial fees?
    does it include a break down of labor charges or exclude them altogether, because if there is no mention of them, then the driver in many cases won’t get them no matter what.
    No, they are not required to give you the agreement.
    however they are require to give you the actual freight bill they send to the customer on request, be it a broker or a direct consignee.
    this is under 376.12(g), lease agreements.
    also just to add to this, your arrangement with all the parties involved seems to be a bit odd, go to one company and stick with them if you don’t want your authority. Landstar is a good place for a step deck.
