Question about removing Z restrictions
Discussion in 'Questions From New Drivers' started by SteveW48, Oct 16, 2016.
  1. SteveW48
    SteveW48 Bobtail Member
    6
    Oct 16, 2016
    I have class A license with Z restrictions (except tractor trailers)...I need to remove this restriction because of my new job. Will I be able to inspect 5th wheel and trailor and do drive test or will I have to take the whole pre trip over from truck to end of trailer?
  3. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    ,sounds like you'll need to test again but I would ask your local dmv.
    quote:
    Z
    If the driver takes the test in a vehicle with an air over hydraulic brake system, then they will have a "Z" no full air brake restriction placed on their license. In either case the driver is not authorized to operate a CMV equipped with full air brakes.
    https://www.fmcsa.dot.gov/registration/commercial-drivers-license/drivers
  4. SteveW48
    6
    Oct 16, 2016
  5. SteveW48
    6
    Oct 16, 2016
    Thank you
    dca Thanks this.
  6. Jubal3
    Jubal3 Heavy Load Member
    878
    950
    Apr 2, 2015
    Central WA
    Don't sweat it, review everything from school and be ready to do it right.
    I actually did a full-on 108-point inspection the other day because the truck was running rough and I wanted to make sure I hadn't missed everything.
    felt really wierd testing the horns, etc, but it's not stupid. Actually caught a bad wiper and moderately low brake fluid.
  7. RollingRecaps
    RollingRecaps Light Load Member
    293
    391
    Apr 6, 2016
    Hmmm I have never found a place to add brake fluid on this Cascadia mind telling us what section of that 108 point inspection it can be found in :)
  8. SteveW48
    6
    Oct 16, 2016
    I didn't go to school lol. I got my Class A with a air brake dump truck with pintle hook and a 30' electric brakes trailer. Before all this I tested on the general knowledge, air brakes, combination and passes them all.
  9. Ke6gwf
    Ke6gwf Medium Load Member
    412
    406
    Oct 1, 2016
    Napa Valley /Yreka CA
    It goes in the reservoir right next to the muffler bearing.
    Look for the Headlight Fluid filler, and then look to the right.
  10. Ke6gwf
    412
    406
    Oct 1, 2016
    My memory is that for removing an air brake restriction, you have to do the whole driving test again, but you would need to ask your DMV for sure, and get a new handbook, and the right forms while you are there.
  11. thejackal
    thejackal Road Train Member
    1,359
    1,456
    Mar 1, 2014
    detroit mi
    Wow..never heard of z before. I thought that was a Canadian thing. Learn something new everyday
