Question about Reefer Temp
Discussion in 'Refrigerated Trucking Forum' started by Gulsher, Jun 16, 2014.
  1. Gulsher
    Gulsher Light Load Member
    55
    9
    Nov 26, 2013
    Hello Everyone
    I recently bought a 2008 reefer with the Thermoking 210 Unit and I'm kind of worried. When you set up a temp at 34 you notice theat the inside temp runs up to 41 and also goes up and down. is that normal on Thermoking? i've also pulled a Carrier wich doesn't do that.
    Advice please.
    Thanks
  3. TomOfTx
    TomOfTx Road Train Member
    1,190
    1,406
    Jul 13, 2013
    Friendswood, TX
    Are you running it on Continuous or Cycle Sentry? On Cycle Sentry, the unit can warm to about 5 degrees above the set temperature before turning back on. Have you done a manual defrost, especially after the trailer doors have been open?
  4. Gulsher
    55
    9
    Nov 26, 2013
    Yes When you run it on Continious. it does that. I tried the manual defrost also. but when you check the temperature recorder it doesnt show 7 degrees difference. the Unit just plays going up and down to the temperature that you set it up for. I know 2-3 degree is normal but 7 is too much. Maybe it some censor that can be adjusted?
  5. TomOfTx
    1,190
    1,406
    Jul 13, 2013
    Friendswood, TX
    On Continuous, the temperature usually stays within 1 degree of the setting (except during a defrost). A 7 degree difference is a lot, especially if you were to haul produce, so get it checked out. Maybe the display is not an accurate reflection of the real internal temperature since you mentioned a temperature recorder did not show the temperature fluctuation. You wouldn't want to pull into a receiver and have them think the reefer temp was too warm.
    The other question would be the temperature of the product loaded. If it was warm, the reefer may not ever get cooled down to the set temperature, depending on the length of transit time. Do you have a problem maintaining a set temperature with an empty trailer? If so, then I would definitely have Thermo King take a look at the reefer unit.
  6. Dryver
    Dryver Road Train Member
    2,818
    2,575
    Nov 30, 2008
    Sioux Falls, SD
    Look at the seals on the doors and also the insulation under the floor. I've had blown tires shred the under floor insulation. Check the overall integrity of the trailer.
  7. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Knowing what you're hauling would be helpful and if you're running continuous or start/stop. Summer temps are here and produce loaded hot and on cycle would run up that high before starting, but produce should never be run on cycle. Dairy on the other hand, I might be a little concerned. I have a feeling running it on continuous will solve your slightly larger then normal temp swing if you are running continuous, it may be icing up too quickly meaning it needs to get looked at
  8. ShortBusKid
    ShortBusKid Heavy Load Member
    955
    1,269
    Dec 5, 2010
    Vegas
    The only time mine does this is when it's froze up. I have a carrier now but I have had to turn off and back on both a carrier and TK unit to get them to defrost properly. This has happened to me a couple times when loading out of the Rio Grande Valley when it's HOT and HUMID.
  9. coolrider101nk
    coolrider101nk Light Load Member
    50
    41
    Mar 24, 2008
    I would take the time to go through all of the settings on the unit and reduce the defrost times as much as it will allow and minimize the variances. It's always a good idea to check deep in the settings because I've seen some that I would think a 5 year old was seeing how much damage they could do. If it is set to defrost every hour it isn't going to be able to pull back down and maintain a good temp. Also....I'd suggest getting a laser thermometer to verify the actual temperature rather than just the unit readings.
  10. PaulDark
    PaulDark Bobtail Member
    4
    Feb 15, 2020
    Gusher, did you figure out ahat the problem was?
    Mine does the same thing, lets say you set it at 65f, it would cool down to like 59-60 and will heat up to 70 and cycle starts over.....
  11. abyliks
    abyliks Road Train Member
    3,742
    8,691
    May 2, 2010
    ludlow MA
    Buy a laser temp gun and make sure that’s the actual temp, if it is, Unfortunately I would start at a tk dealer and have them put a computer on it to make sure it’s not programmed to have that much of a swing, like maybe if the original owner was hauling something not finiky, then I would start with sensors, providing the doors and walls have no large gaps.
    is the high speed working? If not it might just be taking longer to come down to temp
