Hey guys back again here, I’m getting ready to do an inframe on my 3406b 7fb 350hp cat engine, my question is, is it possible to throw a C model cylinder head and exhaust manifold on a B model block crank and pistons? I’d like to eventually turn this into a C model but wondering if this is even possible just using the block I have and than swap a c model crank and pistons into it get a c model pump too just spitballing here trying to see how far I can get with what I have. T.I.A
Question about inframe on 3406b 7fb 350hp cat engine
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 85pete359, Feb 27, 2023.
Page 1 of 5
If your fix'n to go to all that expense .. why not just pull the B model and swap in a C model ?
Keepforgettingmypassword, W923 and Rideandrepair Thank this. -
I don’t know the answer but I can provide disposal services of the b model lol
I think any time you change a crank, the block needs to be line bored first. That’s what I was told recently by Detroit, anyways. In other words an out of frame overhaul. They claimed you can’t just swap a new crank in, I’ve also been told it needs to be done on a second or third overhaul. Maybe it depends on the engine and amount of torque it has? I don’t know. My Detroits on its second inframe. No need to line bore. Not enough torque to stress and twist the block. I’d guess the heads are the same. I don’t know enough about them even though I had a C model for 4 years. @wore out is who would know for sure.
Keepforgettingmypassword and Rideandrepair Thank this.
Rideandrepair Thanks this.
A C model head won’t flow as well as a B. That said you can’t get the B square port head from CAT any longer. All that’s offered is round port. The B square port manifold will seal on a round port head, and actually is Bigger has better flow that a stock round port manifold as well as the aftermarket round port manifold I run. That said I think a round port head does better with a round port manifold.
Don’t let the uninformed convince the bottom of a 7FB is weak. Is a C stronger looks to be yes so we’ll go with that. However I have seen too many narrow journal engines turn 2350 all #### night, night after night dragging a cow bus across 80. I have seen as many crank failures on C as B. C has way more rotating mass something to think about.PSM379, mile marker 27, 85pete359 and 4 others Thank this. -
Rubber duck kw, W923, Rideandrepair and 1 other person Thank this.
For what we’re doing and who we’re doing it with square port head or round doesn’t make enough difference to matter in my opinion. I run a round port with an after market manifold cause it’s the head I got from CAT. I think if you’re pulling a sled or racing it would absolutely matter. But for street use I’d use what is good and availablelittle cat 500, W923, Oxbow and 2 others Thank this.
Page 1 of 5
